![]() | Home > Technical (L405) > Front Windscreen / Windshield Interior Air Temperature |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
The black casing behind the mirror give this fault, and similar, if it's faulty...
heretolearn Member Since: 27 Oct 2024 Location: Kuala Lumpur Posts: 56 ![]() ![]() ![]() |
Thanks for the reply. Yeah I'm trying to figure out the sensor placement and which sensors to order just in case mine is faulty. A sensor read of - 2048 celcius can't be right on an average 37C weather lol.
hmallett Member Since: 21 Jan 2024 Location: Mid-Wales Posts: 155 ![]() ![]() ![]() |
The windscreen temperature sensor is a single unit with three sensors: interior temperature; windscreen temperature; humidity. It's part number LR058011. It's easy to replace. |
Thank you for the info. By any chance you have the instructions on how to remove the plastic cover? |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1878 ![]() ![]() ![]() |
Not strictly the same thing I realise, but some of the nformation in this thread may be helpful:
It "just" pulls off, though on mine it was quite stiff. |
Awesome! I'll try open it up on the weekend to check if its plugged properly. Worse case I'll order a new sensor. Fantastic help guys. |
Muminek25 Member Since: 13 Apr 2025 Location: Warszawa Posts: 3 ![]() ![]() ![]() |
Did replacing the sensor solve the problem? |
I haven't gotten around it yet. Likely it is unrelated. There were 2 temp open circuit reading on engine side, but those sensor don't exist in the SDV8 platform. So this is low priority since there isn't any codes on diagnostics to suggest it needs to be addressed. Anyway my AC works fine. Rear blower seems stronger than the front. Front driver side vent seems a tad bit mellow though. Probably too much effort to tear down the dashboard just to check on the vent control motors |
