Home > Maintenance & Mods (L322) > Clamp Meter
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
Clamp Meter
Can anyone recommend a decent clamp meter, my new battery has gone flat after sitting for 4 weeks (this isn’t the first time) so it looks like I need to track down whatever is draining the battery.
I have no idea how to do this so will be doing a read through of whatever threads there are while waiting for my meter.
Thanks
Post #724326 11th Sep 2025 10:54am
Gsxr1250dave
You can just use a cheap multi meter connected up to the battery then start pulling fuses until you find it. Thumbs Up
Post #724334 11th Sep 2025 12:49pm
pcourtney
England 2011 Range Rover Vogue 4.4 V8 Sumatra Black
or one of these, which is a lot quicker , £12.50 or so
Automotive Current Tester Circuit Meter Standard ATO ATC Blade Fuse Car Vehicle
https://www.ebay.co.uk/itm/400433639239
Post #724336 11th Sep 2025 1:01pm
JoolsB
I didn’t even know these existed, many thanks, a weekend of fuse pulling awaits.
I presume I just power everything off as far as possible and go through the fuse boxes methodically?
Post #724356 11th Sep 2025 5:37pm
pcourtney
The cheap one I posted the ebay link for, sadly it only works up to 20 amp fuses ( its basically a Chinese copy of the Sealey model TA120 which I have) , I am still looking for a cheap fuse tester that does up to 80 amps, as the Range Rover has a few 40a, and I think some mega 50a fuses.
This one on ebay is rated up to 80 amps, so I will probably get that
https://www.ebay.co.uk/itm/146607864199
What I can tell you is that modern cars of any type, do not like fuses being removed willy nilly, it can cause some weird issues with ECU's and computers on cars ( and we have nearly 30 of these ECU's on later Range Rovers)
Post #724357 11th Sep 2025 6:02pm
stuart_2006
If you still want to go down the clamp meter route, I got a UNI-T UT210E (https://www.ebay.co.uk/itm/335675411604) which worked well monitoring the current drawn from the battery.
Post #724364 11th Sep 2025 7:26pm
pcourtney
also good info is posted on this thred below if using a multimeter to get some idea what is drawing amps when car in sleep mode
You really need to get the Range into sleep mode, for any of this to work properly, so you need to push all the door, bonnet & tailgate latches to their closed position (but with the doors open) so that you have full access to the inside of the vehicle without activating any of the door latches which will, of course, wake up vehicle systems. Then wait about 20 mins or so for it to sleep.
NB remember to open the glove boxes and tape the latch on those as well !
https://www.fullfatrr.com/forum/topic68662.html
Post #724365 11th Sep 2025 7:34pm
