Home > Technical (L405) > 2014 SDV8 help needed
RRRyan
United Kingdom 2014 Range Rover Autobiography SDV8 Santorini Black
Hi all just looking for a bit of help here. Basic story is the full engine loom and the engine bay loom have been replaced. Now I am getting a fair few faults if I post everything can anyone help. My main issue is no start just cranks comes up with crank sensor fault but I know the crank sensor is good it’s been changed recently.
My theory is there a broken earth or something as I think I’m not getting full comms with the whole car as can be seen in the photos
Post #726745 23rd Oct 2025 7:54pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Certainly seems like there are quite a few modules not communicating, can you talk to the KVM unit?
The B100D-67 column lock authorisation error would cause a non start.
What inerface are you using with SDD, if it's a cheap mongoose clone there was an issue with these where they would short the HS Can bus out on early vehicles (and the dash would light up like it was Christmas), seem to remember removing pin 13 solved the issue.
Obv. if it won't start with SDD not connected then it's not the Mongoose creating the problem. I assume you've checked all main earth points in the engine bay? L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #726761 24th Oct 2025 8:26am
RRRyan
Yes I can communicate with the kvm I sorted the steering column lock by grounding it to the body from the ground pin on the plug for the esl
I have checked all the ground points I can see yes as both front end looms have been changed
I have sdd i use with a genuine passthru device
And I have Autel im508
Post #726774 24th Oct 2025 11:31am
4RRS
What is the CKP fault you are getting?
Here's a graphic showing all earth points, bit of a task to go through them though!
https://www.fullfatrr.com/gallery/albums/u...ck-Ref.pdf L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #726775 24th Oct 2025 11:37am
RRRyan
Here is pictures of the fault code
Post #726790 24th Oct 2025 3:02pm
RRRyan
But these are the ones I’m mainly concerned about
Post #726792 24th Oct 2025 3:14pm
RRRyan
If anyone could help I would really appreciate it I’m pulling my hair out atm
Post #726985 27th Oct 2025 3:15pm
Gremlin500
I suppose you already checked the main wheelarch earths?
It’s an earlyish car, so these could be suspect.
I wish I could help more, sounds like a nightmare Sad V6 Vogue - “Less is More” - less to go wrong!
Post #726986 27th Oct 2025 3:32pm
4RRS
Has the engine run since the ckp was changed?
What brand did you install?
Was the reluctor ring changed?
Have you looked at live data for the ckp as you should be able to pickup an abnormal waveform even when cranking?
Give us a bit more background about the vehicle and why the looms were changed etc.
Is the battery fully charged as quite often U codes can be down to low battery voltage, have you checked the main earth's for the ABS module under the offside front wheelarch as these are known failure points L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #726987 27th Oct 2025 3:38pm
nike_bytom
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
Hi,
Did you fit brand new looms or second-hand ones? I’m assuming the exact same part number looms were fitted, with the same revision?
I had a similar problem on my Evoque with the HS-CAN and the car not starting — it turned out to be a corroded splice on the HS line above the rear differential. I’m thinking it could be similar damage to the HS line somewhere on the engine loom.
Get the wiring schematic for the engine loom and work out the pinouts for the HS line. Then try running a single wire from the ECU that isn’t communicating to the ECU that is communicating on the HS-CAN, just to see if that restores communication.
Raf L405 4.4 Vogue
L538 2.2 Prestige
Pozdrawiam
Rafal
Post #727087 29th Oct 2025 6:26am
