![]() | Home > Maintenance & Mods (L322) > Damped opening of lower tailgate |
Astron21 Member Since: 22 Jul 2010 Location: Moscow Posts: 4 ![]() ![]() ![]() |
Could you please explain in a detail how you've fitted the nuts on the back? I have removed the caret cover but still no idea how to push it inside because it's all covered with metal... |
Aurrian Member Since: 29 Aug 2011 Location: Glasgow Posts: 107 ![]() ![]() |
I also found that the self tapping nuts were not secure, and looked difficult to get in to put nuts behind so I used "rivnuts" as suggested by someone earlier on;
Finally have expanded/drilled the technological hole under the carpet cover near the bracket and installed the nuts through it |
goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196 ![]() ![]() ![]() |
There is already a hole around 1cm diameter ~10 cm away from the bracket installation place, I have only expanded it to 4 cm in diameter |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 884 ![]() ![]() ![]() |
Just did this nice upgrade, ordered the parts from brit-car.co.uk (including the two screws), drilled two 5mm holes and then used a 6mm plug tap for the threads. All OK! The second photo from the first page was very helpful! |
philbathurst Member Since: 28 Apr 2013 Location: Iver Posts: 143 ![]() ![]() ![]() |
lovely bit of kit
RRBlue Member Since: 24 Feb 2012 Location: Cambs Posts: 226 ![]() ![]() ![]() |
Very satisfying, if a little sad according to the family.
vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390 ![]() ![]() ![]() |
have done this upgrade today - what a difference that shock absorber makes - open much better and in line with what one would expect of such a luxury vehicle |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3668 ![]() ![]() |
Hi all just thought you'd like to know I've just found someone on ebay with the lower tailgate release button upgrade for £2.39, free carriage!!!!!!!!!!!!!!!!!! I know it might be a bit late for some of you, but for anyone new to the site, blinding result!!!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35863 ![]() ![]() |
good find.. |
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 ![]() ![]() ![]() |
Yeah but, It would cost me a tenner in PETROL for return trip to the main stealer
I've got an oil burner and a LR main dealer 5.5 miles away, and I reckon that it would workout more expensive, plus I can smurf the web and let the postie do the work |
I have been looking in to doing this conversion on my ffrr, but, it would appear that the boat has sailed on reasonably priced parts. The current price from Dan is £63 |
