Home > Maintenance & Mods (L322) > Got new style flip key to work..!
Page 5 of 9 <123456789>
robbo770
Scotland 2005 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Hi Daveo, and everyone else,
I am almost falling of the chair typing this, but the place I got the keys responded today and have said they are going to send out 5 blades of the wide type B format to me, but i will believe it when I see it!
I am away for just over a week in the States so I will not know till I return after next Monday.
so if you can all sit on the fence till then, I may save some costs on blades for all that waited,
will advise an update on my return, failing this working.... Daveo has a solution to get all the blades change for a nominal costs, still cheaper than buy a factory set one thats for sure.
anyone who does manage to get this to work remember the forum relies on posts with pictures step by step to allow other members to follow and acheive a sucessful mod, so remember the CAMERA!!
cheers
Rob Current vehicles
4.2 SC FFRR RSE 2010- facelift
Range Rover Evogue Dynamic Lux
Gone
Rejected RRS my14.5 nightmare
Disco B4 XXV convert
Freelander 06 SE
06 RFFRR 4.2 SC Vogue RSE
Audi A8 4.2Tdi Quattro (hated with a vengence!!)
54 FFRR 2005 model V8 4.4 Cobra Variant
53 Mitsubishi Shogun V6
Post #121219 10th May 2012 8:52pm
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
The only problem I have encountered is the fob won't stay glued closed, I have tried so many different types of glue! I still have the cable ties on just in case it springs open.. Thumbs Up
Post #121232 10th May 2012 9:46pm
supershuttle
When I have struggled with glueing I have used two part epoxy never yet failed. Geoff
Post #121234 10th May 2012 9:49pm
daveo
hi all, with reference to robbo's last post i will hang five on ordering the spare key blanks,he is away for a week but if you fill you still want one regardless then let me know.
don't forget if you try to sync your key you must sync your original key in the same operation or you will knock it out and it wont work..
with regards to gluing the two half's together i found that a good quality glue is a must and it will help to clean the two half's that will touch,even a light sand just to key up the plastic. i imagine that they some form of releasing agent on them when they were molded. V8 facelift Range Rover Autobiography 22" wheels.
Post #121240 10th May 2012 10:13pm
robbo770
Hi Dave,
could you write a detailed sequence to help all concerned with the do's and don't of how to load the new key into the cars.
I know it would help me so definately will help everyone else too!
cheers Thumbs Up Thumbs Up Current vehicles
Gone
Freelander 06 SE
Post #121253 10th May 2012 10:51pm
daveo
Programming a new Key
Replacing a missing master key is quite expensive from Land Rover, try not to get sucked into the extra cost of "Dealer coding" You can do this yourself in 2 minutes by following the simple process below.
1) Get in and close all doors. Turn ignition on and off quickly and remove the key (all within about 5 seconds).
2) Within 30 seconds of turning the ignition off, while holding down the "unlock" button, press the "lock" button three times. Release the "unlock" button. (You may or may not get the confirmation from the door locks they should lock and then unlock.) Holding the key at your head level provides best results as the key sensor is in the side window pillar.
3) Repeat for each key you want to initialize within 30 seconds after the last one you initialized (if you have more).
4) Right after doing the last key, quickly put the key back in the ignition and turn it on/off again to
you may find it easier to do this holding the circuit board then you wont worry about if you have pushed the button correctly, some work first time ans some take several attempts but listen for the door locks to cycle then do the same on the original key V8 facelift Range Rover Autobiography 22" wheels.
Post #121259 10th May 2012 11:15pm
Do these new keys req the old transponder to be put inside? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #121313 11th May 2012 12:31pm
Lolo
Instructions
Yes it's on first page..
1. Get new blade cut check it works in door.
2. Put old transponder in new remote.(little black wedge)
3. Try new key in ignition and go for drive to charge fob
4. Follow daveos instructions above to enable remote central locking.
5. When happy everything works, glue together.
It's that easy.!! Thumbs Up Very Happy
Post #121314 11th May 2012 12:58pm
How do you get the blade out? I've tried pushing the split pin but to no availe. Do I need to use more force? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #121462 12th May 2012 12:15pm
Lolo
No force is needed. The blade pops out with the silver button thing still attached. Just make sure u dont lose the little spring inside. When ur putting the blade back in u need to wind it on the spring, so when u press the button it springs open. Hope that makes sense.
Maybe someone has a picture for u.
Post #121466 12th May 2012 12:30pm
daveo
i think he is talking about the blade, yes there is a pin in side, one hole i slightly larger the the other so that's the hole it comes out of, you can use a nail or any thing pointed as when it goes in it will force the pin open and hold tighter, i use a link extractor as its a harden pin with a flat end fit in the hole 100%, now you need to get it firmly seated and flat, NO vice or pliers as you will end up marking the chrome blade holder, if you rest it on a bit of soft wood and start it of you will see it coming out of the bottom, once you have it started you can line it up over a hole and knock it out, do not grip it with pliers as you will crush it and it will never go back. V8 facelift Range Rover Autobiography 22" wheels.
Post #121478 12th May 2012 1:32pm
Lolo
Ok lads, seriously, it seems yous are making this harder than it is. Laughing
I know he was on about the blade. I just took out the whole chrome bit with blade still attached. Key can still be cut with that on it. Thumbs Up
Post #121480 12th May 2012 1:35pm
Lolo
Only copping on that the new fat blade won't have chrome holder on it, hence why ur trying to get skinny one out..!
Don't mind me, Ill stay out of this now..! Rolling with laughter
Post #121482 12th May 2012 1:46pm
robbo770
email from the supplier received today, they have informed me they are senting out the correct blades, as your aware in US at the moment so well have to wait and see when I get home what they send.
thanks Current vehicles
Gone
Freelander 06 SE
Post #121498 12th May 2012 6:10pm
daveo
hi all, to all those that had the flip key from robbo, could you check to see if you have both chrome corner to the remote, one holds the key and the other is if you want to fix to a key chain, as my one has only the one.... V8 facelift Range Rover Autobiography 22" wheels.
Post #121506 12th May 2012 7:41pm
