Home > Technical (L322) > Suspension again |
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 |
yep you will
15th Sep 2013 11:51am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
Depends on the code reader and what you do with it Live data is very helpful in cases like yours... Checks temps, pressures, actuators etc etc etc |
15th Sep 2013 11:52am |
Paulhh Member Since: 23 Dec 2012 Location: Carrbridge Posts: 143 |
Here we go, just had the errors read:-
15th Sep 2013 5:39pm |
jeff64 Member Since: 14 Sep 2013 Location: sth.yorks Posts: 14 |
[quote="Paulhh"]Cheers for that, I guess you might be right. Have to bite the bullet and spend the £400.[/quo te] if you do have to change the compressor, i got one about 3 months ago from PADDOCKS of MATLOCK £230 + vat including relay, i collected mine so dont know how much delivery would be. hope this helps. |
15th Sep 2013 6:09pm |
Cheers Jeff.
15th Sep 2013 7:11pm |
Sensor voltage seems equal and right according to your description
15th Sep 2013 7:27pm |
Adigorn
15th Sep 2013 8:18pm |
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 |
Sorry paulhh, benn out all day, from your post it sounded like the compressor was running for a few seconds then shutting off, I meant try running it without the control of the EAS module by feeding it 12v, see what it does. If it shuts off quickly, it must be the electric motor of the pump giving up, yes? |
15th Sep 2013 8:34pm |
No the ecu shuts it down couse id does not meet it expectations Pressures, load on the motor , sticking valves etc |
15th Sep 2013 8:40pm |
Hi Paneldamage, I'll maybe give that a quick go tomorrow. Although i think adigorn is right. Everything is pointing to a knackered compressor I guess, I have never heard of the faults listed, I.e. drain valve, so I was thinking that the reservoir was full but I'm no longer sure about it. 2002 Vogue Epsom Green with Ivory Leather.
15th Sep 2013 8:41pm |
Just stripped the compressor again to check piston ring. When I disconnected it from the car there was quite a bit of pressure in the pipe, makes me think the compressor is fine.
16th Sep 2013 7:54am |
First we need to find out what the normal system pressure should be for the car to lift. 810 KPa (Edit 8 not 0.8 bar) may not be enough. Or if a valve is closed/sticking, the compressor pumps the bit of the system before the valve to the correct set pressure (assuming that is 810 KPa) and stops as per design but the air is not going to the bags due to the sticking/stuck/closed valve.
16th Sep 2013 8:28am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1274 |
810 kpa is 117psi , I'd suspect that pressure is normal operating pressure for the comp. tbh. |
16th Sep 2013 9:24am |
Sorted
16th Sep 2013 12:33pm |
