Home > Maintenance & Mods (L322) > WARNING change your diff oil!!! |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Take it to the dump for recycling. Alternatively...... |
22nd Jan 2015 12:55pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34927 |
where's the oil residue from ryan? ... - .- -.
23rd Jan 2015 6:34pm |
WD40 Stan... The residue/ deposits are only the results of my prep for when I eventually buy the correct tools to undo the plugs!
23rd Jan 2015 10:21pm |
This is also a useful set to have
23rd Jan 2015 10:42pm |
Done it! Rear Diff oil changed today, by me
25th Jan 2015 1:23pm |
markcaughey Member Since: 03 Nov 2014 Location: Glasgow Posts: 316 |
did the syringe do the job then ? did you take the car a run first to heat the oil ? Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE ) |
25th Jan 2015 1:56pm |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 350 |
This is the tool to help fill both front & rear difs
25th Jan 2015 7:57pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16174 |
How much debris was on the magnet? The DARK BROWN colour is rust |
25th Jan 2015 8:02pm |
Craig, the magnetic part of the drain plug (both filler and drain plug faces actually were/ seemed) surprisingly clean, although the threads needed a clean.
25th Jan 2015 9:20pm |
Mark,
25th Jan 2015 10:19pm |
Its amazing how the rear diff oil degrades isn't it The colour will be down to the internals of your diff rusting due to water ingress (i suspect condensation) then its only a matter of time before A, the bearings give up! and the rust makes the driveshaft seals blow! Good job you caught it when you did sir |
25th Jan 2015 11:04pm |
nice one Ryan, hopefully my stuff will arrive tomorrow.
25th Jan 2015 11:54pm |
I did Mark yes but its A, my weekend off sir & B, been a dreadful weekend (personal) so NO SIR i have not & don't intend answering until the morning sir
26th Jan 2015 12:36am |
Craig, would you hope that this oil change (plus future 30k mile changes) should 'save the diff' if the brown coloured oil might be indicative of condensation build up rust that could lead to failed bearings and driveshaft seals? Thanks. |
26th Jan 2015 7:49am |
