Home > Maintenance & Mods (L322) > Rear lower arm bushes |
The two bushes that sit in each of these lower arms, does anyone have a part number for them at all as my front ones are dying and squeaking like a mouse that's just found 2tons of lancashires finest crumbly cheese!!! 😬😬😬😬 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
28th Aug 2016 4:04pm |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 |
Rear as in rear of car or the arm behind the control arm RAVE calls a tie rod? |
29th Aug 2016 12:20am |
Rear of vehicle 👍 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
29th Aug 2016 5:49am |
Roverlord Member Since: 20 Aug 2016 Location: london Posts: 29 |
The fronts bushes are probably RBX00070 and RBX000200 which supersedes to LR018345 |
29th Aug 2016 1:56pm |
Try using Rockauto.com for part numbers. I assume it is a US only company but it is great for looking up parts and cross reference for part numbers. I found this under suspension /control arm bushings MOOG K200836. Depends which one you need. They may all be the same for the rears. |
29th Aug 2016 3:17pm |
This is one of the arms
29th Aug 2016 3:47pm |
Yep the ones I quoted should do it
29th Aug 2016 3:52pm |
Thanks NMJ 👍 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's Mantec Sump Guard, Rigid Load liner, MY10 BT upgrade. |
29th Aug 2016 3:56pm |
Just seen that I can get the arms for £108 each and engine so if these include bushes I'll go for that option! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
29th Aug 2016 4:08pm |
Looking at the microcat pic, it shows it with the bushes so it would appear that it does indeed include the rubber bits. Probably an easier job than pressing out the originals. There is nothing that can't be fixed with a hammer😜😜
29th Aug 2016 4:24pm |
That whole wishbone cost $325 US here. I found this nice reference pic on Amazon.
29th Aug 2016 4:33pm |
Sorry, your title it said rear arm and in your post you said your front ones so I misresd and thought you were after new front ones as well. |
29th Aug 2016 11:36pm |
Those part numbers are not land rover part numbers. Some sellers sell them under their own part numbers.So if you went searching on those part numbers you would not find a comparable price quote to compare. |
29th Aug 2016 11:40pm |
Yes but it is a nice diagram for reference and often you can find the cross reference if you have some number. The hard part is that the different suppliers use different terminology for their part location and descriptions. Very frustrating. |
30th Aug 2016 12:53am |
