Home > Technical (L322) > TDV8 no power, white/blue smoke |
gsmith1 Member Since: 13 Dec 2012 Location: Australia Posts: 6 |
Hi rar110,
18th Sep 2016 10:20pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Gday
19th Sep 2016 12:40am |
Thanks rar110, I ordered a set today from Auto Code, www.autocode.com.au
20th Sep 2016 9:43am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6666 |
http://store.autocode.com.au/egr-emulator.html
20th Sep 2016 10:51am |
It runs a bit quieter and much less black smoke out the back on acceleration. I read that the EGR helps bring the motor up to temp a bit faster. I tend to give it a little more time to warm up before I give it a boot full. And you don't get the EGR cycling noise on shut down. ______________________________
20th Sep 2016 11:53am |
Very tempting for when the RGR's finally throw in the towel.
20th Sep 2016 12:11pm |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1328 |
My understanding is that, in the UK it will fail an MOT if the EGR's are by-passed or disconnected.
20th Sep 2016 1:57pm |
Whys is that? Does it have an effect on the emissions check? Got - 2017 SDV8 Autobiography in Loire Blue
20th Sep 2016 2:10pm |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 |
If it was fitted with EGR from the factory, then it has to be present for MoT. Same for DPF and Cats.
20th Sep 2016 3:09pm |
So, assuming the MOT tester probably won't even open the bonnet, it's a bit of a moot point then? Got - 2017 SDV8 Autobiography in Loire Blue
20th Sep 2016 4:43pm |
it is a moot point, however assuming they are plug and play, then you could just plug the EGR back in for the MOT There is nothing that can't be fixed with a hammer😜😜
20th Sep 2016 8:15pm |
I doubt an inspection would identify what it is if the bonnet was opened. But yes can be put back to factory in a couple of minutes by unplugging the emulators and plugging in the EGRs. ______________________________
21st Sep 2016 8:39am |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
I had my EGRs turned off a few weeks ago and it has stopped the puff of smoke that used to appear on initial hard acceleration It was done while being remapped with no extra cost 2015 4.4 AB
21st Sep 2016 5:50pm |
Who did the remap? ______________________________
21st Sep 2016 10:13pm |
