Home > Maintenance & Mods (L322) > Engine Cutting Out Intermittently - 2012 4.4 TDV8 |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3676 |
11th Feb 2017 3:59pm |
bwelton Member Since: 26 May 2014 Location: Milton Keynes Posts: 137 |
Is that definitely the 4.4 TDV8 2012. I can't find it... |
11th Feb 2017 4:11pm |
11th Feb 2017 4:12pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34918 |
11th Feb 2017 4:44pm |
Ok, removed and reseated 3 connectors and refitted.
11th Feb 2017 6:17pm |
Ok. Problem still there. I managed to capture of log of the engine waivering in Revs and then cutting out.
11th Feb 2017 9:55pm |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 |
do you get any variance in the two MAF readings ?? Regards
11th Feb 2017 10:31pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2308 |
The 2nd MAF's values will be of no consequence at idle. |
11th Feb 2017 11:25pm |
who said anything about at idle
11th Feb 2017 11:29pm |
The graph shows engine speed as idle or not much more. The 2nd turbo doesn't get used until around 2500 rpm so I expect that its MAF wouldn't see any airflow.
12th Feb 2017 1:31am |
Hi All,
12th Feb 2017 9:00am |
Perhaps the ecm/pcm reported voltage if it's available. |
12th Feb 2017 9:34am |
Thx,
12th Feb 2017 11:58am |
Ok. voltage at PCM seems a static 14.7V
12th Feb 2017 12:47pm |
