Home > Technical (L322) > Lack of power - S/C |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 |
Drove into work this morning and put foot flat on floor and used kick down, car didn't want to go above 90 and when it got there, I heard a whistling noise (almost like a blow-off valve) from behind the glovebox and no more acceleration.
26th Jun 2017 8:35am |
Just used one of the guys fault readers at work and no faults in the car at all. Not to say that this is correct as it may not pick them up.
26th Jun 2017 9:42am |
I have already had mine replaced at LR nearly two years ago so would have hoped that as it has been replaced it would be wired correctly.
26th Jun 2017 10:49am |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3062 |
@ Zarnd - don't count on it. I had to tell the "Tech" that he was trying to put the MAF on UPSIDE DOWN!! |
26th Jun 2017 11:27am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
Where is the autobahn in Kent then? .
26th Jun 2017 12:19pm |
26th Jun 2017 12:24pm |
Crispian22 Member Since: 25 May 2017 Location: Midlands Posts: 133 |
Running out of fuel generally will cause a lack of performance |
26th Jun 2017 2:21pm |
I spoke to local LR dealer and told her what the car was, gave the registration number and said it was supercharged.
26th Jun 2017 2:30pm |
I have a video below. I can't go above 70mph now and get a constant hissing noise under WOT. A quick peek under the bonnet doesn't reveal anything.
28th Jun 2017 9:32am |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2215 |
When you say above 70mph I assume that is in top so is it a rev limiting problem or a final drive problem ? |
28th Jun 2017 9:38am |
I would say rev limiting rather than driveline issue Alex
28th Jun 2017 9:44am |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
It sounds like a bearing noise. ______________________________
28th Jun 2017 10:48am |
It seems more like the sound of air in the intake. Will try and pop the engine cover off and hopefully find a failed hose.
28th Jun 2017 11:07am |
Took the engine cover off yesterday at work and checked all visible hoses and pipes, all seem ok. Next step today or tomorrow is to take out an exhaust sensor and check the cats to see if one has broken up.
29th Jun 2017 8:12am |
