Home > Technical (L322) > Lost all keys |
DeRanged Rover Member Since: 16 Feb 2012 Location: London Posts: 379 |
There is a process for pairing the transponder to the Key. I had to do that when I got a new key
23rd Aug 2017 3:03pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I'm in kent about 30 miles east of london so probably a bit out of his way, I am going to try once more with the guy that tried the first time but you could answer me this, did your man take out the EWS module and send it off to be read and paired with a new key or did he do it at the vehicle, thats if yours is pre 2006 ish. This guy sent of the EWS module. thanks for the reply |
23rd Aug 2017 7:56pm |
thanks for the reply, I had a look but the problem we have is that although we can open the drivers door with the key, the alarm goes off and although the key should still turn in the ignition, it doesn't so i can't follow that procedure. The man that supplied the replacement key says there must be another fault with the vehicle which is topping the key from turning like a blown fuse supplying the EWS etc so i will check that when the battery goes back on fully charged. There are also two separate processes, one to pair the alarm / central locking so the fob opens the doors and then a separate procedure for pairing the transponder to the ignition switch to allow it to turn. Hopefully get this sorted soon thanks guys |
23rd Aug 2017 8:00pm |
Johnsd1v8 Member Since: 06 Jul 2017 Location: Cheshire Posts: 190 |
Holidaychicken mine is a 54 plate model year 05 he did mine at the car pluged something into it a read some numbers or codes they were and hey presto |
23rd Aug 2017 8:45pm |
I searced everywhere with in a 60 mile radius from me no one said they could do it then i found this company called star keys in chester near me in cheshire he said yes i can do that sure enough he did |
23rd Aug 2017 8:47pm |
Thanks guys, this leads to me to confirm even further that the guy my friend paid a load of money to doesn't have a clue what he is doing.
24th Aug 2017 12:52am |
I had 1 key but the man i used didnt need to do anything with that key he came to my house was there about 2 and a bit hour job done |
24th Aug 2017 6:02am |
ok, thanks for the info, I'll try ringing him again tomorrow and arrange something for next week. |
24th Aug 2017 7:03pm |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 |
You still not got this sorted? My offer still stands send me the EWS and keys I will check everything is programmed correctly for free (well just return postage) |
26th Aug 2017 3:29pm |
Latest is.....
26th Aug 2017 3:31pm |
Thank you for that, he has only just got the genuine key through and i am trying to get the original programmer to come back and sort it but if he can't or won't i may take you up on that which will be a great help as it will tell me if I need to trace the problem to elsewhere. the guy reckons the genuine key should work straight out the box but i dont think that is correct He said the unit was EWS but it isn't it is the later YWC500234, would that make a difference to what you can do ? The vehicle had literally taken root outside his house but the police were going to tow it as it was sorn but he had only put it on the path but they cut him some slack as he is unwell but would have come back and taken it at some point so this encouraged him to get it sorted and now it's on my drive ........ This is a pic of the ECU, luckily the guy couldnt be arsed to fit it back in it's proper place so it is visible under the cup holder location. Many thanks |
26th Aug 2017 9:54pm |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 701 |
just marking this post so i can follow it
27th Aug 2017 5:06am |
Wow, that's a bit steep, the one we purchased was £150 and they said 3 weeks but arrived within a week - doesn't work though
27th Aug 2017 12:10pm |
I wonder if you could buy from my local dealer direct the same as I did, if they won't send it to the states I could pick it up and mail it on a courier of your choice or send the courier into the landrover dealer yourself to collect it? Guy Salmon in Maidstone Kent supplied mine and APC couriers are on the same estate. |
28th Aug 2017 1:08am |
