Home > Technical (L322) > TD6 Intermittent judder / injector fault |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 776 |
You could treat yourself to one of these kits if you have more issues..https://www.ebay.co.uk/itm/BMW-335-D-Brass...SwKrhVbXHL 2007 TDV8 VSE
20th Dec 2017 10:31pm |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
Brass connectors look fancy but I'm hoping that I've seen the back of it!
20th Dec 2017 10:36pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I've fitted those brass injector bleeds as i got fed up with the plastic rubbish breaking / leaking, well worth the investment.... I've got them on my Merc too Yesterday I couldn't spell Engineer... Today I are one!
21st Dec 2017 1:11am |
Miggit, I totally agree, they all go brittle along with the hose degrading so it's only a matter of time. 2007 TDV8 VSE
21st Dec 2017 2:51am |
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 |
Great post Paul, really helpful.
23rd Dec 2017 11:43pm |
Hi Paul,
24th Dec 2017 10:25pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Using Faultmate mine reads all zeros when I rev the engine.
25th Dec 2017 10:02am |
That means all the injectors are ok then.
25th Dec 2017 11:16am |
25th Dec 2017 1:35pm |
Thanks for the feedback Paul.
26th Dec 2017 10:14am |
If it is injectors at fault you should get other faults logged as the EMS tries to balance out the cylinders.
26th Dec 2017 11:29am |
30-52 MPH is the more common TCC vibration.. 50-60 is more likely to be a dirty, blocked injector.... it doesn't matter which diagnostic unit you have plugged in, it wont detect blocked nozzles.... A blead off test is the only way! Yesterday I couldn't spell Engineer... Today I are one!
27th Dec 2017 1:33pm |
Thinking about it, I just took all my injectors out and sent them to a Bosch agent to have them cleaned and tested, 2 failed and needed new guts, after the engine was the smoothest I'd ever known it.... If you car has done 80k+ then a complete clean of the injectors will give it another 80k's worth of life... And I had mine done at 110k, just after it all failed 200 miles away from home with a 3 ton trailer in tow
27th Dec 2017 1:47pm |
I agree, and tbh how much difference its made to mine just replacing one injector, I'm thinking about removing the other 5 and getting them tested / cleaned.
27th Dec 2017 2:19pm |
