Home > Technical (L322) > 2010 Heated/Cooled Seat not working |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
one section from the WM:
18th Mar 2018 11:13pm |
Currently no filter fitted in the base unit John. I left it out so I can feel if the fan is running while diagnosing...
18th Mar 2018 11:15pm |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 |
Greg, I noted the following in the WM pages:
So this would suggest all your modules are working correctly, but your seat back has an air leak or is blocked. The WM also says any faults will shut down the system until next ignition cycle off/on. Also, just to confirm, both seat base and back units have temperature and motor speed feedback. If either has a fault though both will be shut off. Hope that helps. Too many toys, not enough time 2011 4.4 TDV8 AB Black |
19th Mar 2018 2:22am |
Clabs Member Since: 08 Mar 2017 Location: Watford, Herts Posts: 125 |
Thanks for the great info John - it certainly makes sense that both the back and base units have temperature feedback. |
19th Mar 2018 9:44pm |
Dano0404 Member Since: 28 Dec 2017 Location: Uk Posts: 44 |
Are these the same as the 2007? As my drivers has failed no hot or cold.
20th Mar 2018 11:48pm |
I can confirm they are the same had seat back off to day. Had the back fan running cold then hot (but not much heat) maybe because I had the back off? They need some pressure perhaps. When I turned the base heater on it cut out completely. So guessing I need the cushion unit?
21st Mar 2018 2:41pm |
It does sound like your seat base blower is faulty Dano - do you have access to a code reader?
21st Mar 2018 9:53pm |
Yes I’ll try get codes read. I wasn’t sure if the driver and Passanger side were the same if they are I could just swap them over as I never sit that side any way. I’ve definitely got heat on the back panel now so it’s just the bottom that’s the issue. |
21st Mar 2018 11:36pm |
Dan, does the fan run on the Base when on cold ?
22nd Mar 2018 9:09pm |
Yes all runs good on cold you can hear and feel the motor work and sucking by the intake. Passanger one works fine. Will try get it plugged in. |
22nd Mar 2018 11:21pm |
Just an update on mine.
24th Mar 2018 8:35pm |
Does anyone know the part number for the base unit?
24th Mar 2018 8:46pm |
That is really annoying Greg and does seem you have been very unlucky if the base blower has gone too. It is odd though because all the posts I have ever read have always been about the back blower. Still, I guess there is always a first time.
25th Mar 2018 8:00pm |
Thanks Clabs.
But i've fitted a brand new unit back there. And it's running nice and warm on the seat back, has done now for two weeks. I might look at the seat back connector block terminals etc. etc. Could it be a shoddy connector somewhere maybe? Will report back. Cheers, Greg . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
2nd Apr 2018 10:29am |
