Home > Maintenance & Mods (L322) > led upgrade |
BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429 |
hi do you have a link for the side light bulbs with the 2 led's ? thanks or what about these one's -dont want them to be to bright http://cgi.ebay.co.uk/LAND-ROVER-RANGE-94-...1e5ae0f464 |
25th Jun 2010 7:41pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
hi they look fine, if like me you were looking for a led similar to a side light, ie it will not stand out in daylight but will look right at night then that will be fine, if you want some thing that can be seen clearly in daylight then you would need the 5xled 360 degree bulb but at night they look so bright they are like dip beam.
25th Jun 2010 11:50pm |
hi, thay are not hard but you need to take your time and dont go at it like a bull or you will break the clips, some people say pop out your mirror and then you can access the clips but if you do a mirror you will be so if you flex the rear cover you can get a good idea where the clips are, i have a set of the nylon trim tools,they ave verious ends, i used one of thes to work my way round the clips, or you can park it a few foot away from the curb and some one will take it of for you
3rd Feb 2011 5:42pm |
Nickj Member Since: 13 Aug 2010 Location: Ipswich Posts: 262 |
Lovely. Sounds a bit like one of those jobs that will end with me breaking something though. Will give popping the mirror glass off a miss i think and try levering off as suggested. I have asked carazy LEDs to replace one of the exterior bulbs in there kit with some that fit the puddle lamps as i don't need any exterior bulbs. Should have in a couple of days. |
3rd Feb 2011 7:05pm |
They have asked me what sort of bulb i need?! Googling suggests i actually meant approach lights ( not puddle) but i think we were talking the same bulb. All i can find is 'capless 6w'
4th Feb 2011 8:13pm |
AMV Member Since: 10 Mar 2011 Location: EU Posts: 152 |
Gents, how do I replace this bulb? Can't find a way to remove the transparent cover
16th Sep 2011 10:35pm |
you need to remove the dash ends not the lens... V8 facelift Range Rover Autobiography 22" wheels.
16th Sep 2011 10:53pm |
Thanks, do you mean the wood trim? How? Santorini Black RR Vogue 4.4 TDV8 |
16th Sep 2011 11:00pm |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1490 |
No just the black plastic D shape end panels. Should give you space to push the lights out from the back. |
16th Sep 2011 11:39pm |
thats the ones, you cant see them unless you open the door.. V8 facelift Range Rover Autobiography 22" wheels.
17th Sep 2011 10:30am |
trafpol Member Since: 15 Jun 2011 Location: Surrey Posts: 141 |
I used a watchmakers screwdriver on the bulb casing itself, it came straight out no need to take off the trim. I found my LEDs on fleabay ( CrazyLED) with all bulbs in one set and all work great with no faults, even the number plate ones. No approach lights in the kit sadly but Im sure the 6W ones will be fine. In total darkness when you unlock the car it looks like an operating theatre in there - fab !! 2006 MY Autobiography. With 'toys' Honda ST1300 Pan European Gone Jaguar 3.0 SE X Type Honda CBR1100XX Blackbird TJF by the way for anyone who knows what that means. |
17th Sep 2011 11:53am |
You've applied force around the metallic ring? I've tried to but with no result As it comes to removing the "D" side panels - from where should I start? I seems to be made of fragile plastic And also passenger it won't help with the passenger light as it's built-in the glovebox Santorini Black RR Vogue 4.4 TDV8 |
17th Sep 2011 7:28pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 |
I hate to say it, but if you look in your handbook there is a section devoted to the replacement of all vehicle bulbs. |
17th Sep 2011 7:50pm |
In fact I read that section and it was very useful but it doesn't say how can you change the bulb in the round lamp Santorini Black RR Vogue 4.4 TDV8 |
17th Sep 2011 7:55pm |
