Home > Maintenance & Mods (L322) > led upgrade
Page 2 of 9 <123456789>
BrianC
hi do you have a link for the side light bulbs with the 2 led's ? thanks or what about these one's -dont want them to be to bright http://cgi.ebay.co.uk/LAND-ROVER-RANGE-94-...1e5ae0f464
Post #21094 25th Jun 2010 7:41pm
daveo
hi they look fine, if like me you were looking for a led similar to a side light, ie it will not stand out in daylight but will look right at night then that will be fine, if you want some thing that can be seen clearly in daylight then you would need the 5xled 360 degree bulb but at night they look so bright they are like dip beam.
that would be to bright for me...
just changed my number plate lamps
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...K:MEWNX:IT
these worked out just right, i didnt want a bulb that was to bright as it lights up the whole rear bumper and they are meant to be number plate lamps, V8 facelift Range Rover Autobiography 22" wheels.
Post #21105 25th Jun 2010 11:50pm
Nickj
2003 Range Rover Vogue SE 4.4 V8 Java Black
daveo, could you elaborate on how you replaced the puddle lights bulbs in the mirrors and what sort of led bulbs were needed. Just bought an LED kit and realised i don't think these lights are part of the kit!!?
Post #48550 3rd Feb 2011 12:36am
daveo
hi, thay are not hard but you need to take your time and dont go at it like a bull or you will break the clips, some people say pop out your mirror and then you can access the clips but if you do a mirror you will be Censored so if you flex the rear cover you can get a good idea where the clips are, i have a set of the nylon trim tools,they ave verious ends, i used one of thes to work my way round the clips, or you can park it a few foot away from the curb and some one will take it of for you Laughing
once you have it off you can see the holder, the dia of the bulb needs to be no more then 11mm to fit in,length was not a prob, make sure its nice and clean in the holder to get good light,
when done just connect the light up make sure you ave the bulb round the right way and works, clip the back on and away you go, at night you will see the difference for sure.... V8 facelift Range Rover Autobiography 22" wheels.
Post #48616 3rd Feb 2011 5:42pm
Nickj
Lovely. Sounds a bit like one of those jobs that will end with me breaking something though. Will give popping the mirror glass off a miss i think and try levering off as suggested. I have asked carazy LEDs to replace one of the exterior bulbs in there kit with some that fit the puddle lamps as i don't need any exterior bulbs. Should have in a couple of days.
Post #48632 3rd Feb 2011 7:05pm
Nickj
They have asked me what sort of bulb i need?! Googling suggests i actually meant approach lights ( not puddle) but i think we were talking the same bulb. All i can find is 'capless 6w'
Is this the description i mail or is there a better description. don't want to ask for wrong bulb!!
Post #48847 4th Feb 2011 8:13pm
AMV
2011 Range Rover Vogue TDV8 Santorini Black
Gents, how do I replace this bulb? Can't find a way to remove the transparent cover Neutral
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Santorini Black RR Vogue 4.4 TDV8
Post #81943 16th Sep 2011 10:35pm
daveo
you need to remove the dash ends not the lens... V8 facelift Range Rover Autobiography 22" wheels.
Post #81950 16th Sep 2011 10:53pm
AMV
Thanks, do you mean the wood trim? How? Rolling Eyes Santorini Black RR Vogue 4.4 TDV8
Post #81951 16th Sep 2011 11:00pm
Stephen.125
2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
No just the black plastic D shape end panels. Should give you space to push the lights out from the back. Thumbs Up
Post #81953 16th Sep 2011 11:39pm
daveo
thats the ones, you cant see them unless you open the door.. V8 facelift Range Rover Autobiography 22" wheels.
Post #81978 17th Sep 2011 10:30am
trafpol
United Kingdom 2006 Range Rover Autobiography Td6 Buckingham Blue
I used a watchmakers screwdriver on the bulb casing itself, it came straight out no need to take off the trim.
I found my LEDs on fleabay ( CrazyLED) with all bulbs in one set and all work great with no faults, even the number plate ones. No approach lights in the kit sadly but Im sure the 6W ones will be fine. In total darkness when you unlock the car it looks like an operating theatre in there - fab !! Laughing Laughing 2006 MY Autobiography. With 'toys'
Honda ST1300 Pan European
Gone
Jaguar 3.0 SE X Type
Honda CBR1100XX Blackbird
TJF by the way for anyone who knows what that means.
Post #81986 17th Sep 2011 11:53am
AMV
You've applied force around the metallic ring? I've tried to but with no result Rolling Eyes
As it comes to removing the "D" side panels - from where should I start? I seems to be made of fragile plastic Laughing
And also passenger it won't help with the passenger light as it's built-in the glovebox Rolling Eyes Santorini Black RR Vogue 4.4 TDV8
Post #82049 17th Sep 2011 7:28pm
I hate to say it, but if you look in your handbook there is a section devoted to the replacement of all vehicle bulbs. Smile
Post #82054 17th Sep 2011 7:50pm
AMV
In fact I read that section and it was very useful Thumbs Up
but it doesn't say how can you change the bulb in the round lamp Question Santorini Black RR Vogue 4.4 TDV8
Post #82055 17th Sep 2011 7:55pm
