Home > Maintenance & Mods (L322) > dynamic indicators |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
This one on the bay: https://www.ebay.co.uk/itm/5-Step-Sequenti...:rk:7:pf:0
1st Dec 2018 8:48pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34945 |
wow, you have been busy....why did LR make these lights so complicated
1st Dec 2018 9:57pm |
makes sense re a new ribbon/cable...
1st Dec 2018 10:16pm |
thinking that if the rear light unit does have 8 vertical leds then a 4 step module would be best [2,2,2,2] |
1st Dec 2018 10:26pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
https://www.ebay.co.uk/itm/2x-45cm-Car-LED...2443650408
1st Dec 2018 11:39pm |
Nah John the strip won't work.
2nd Dec 2018 12:10am |
Thats my best googling effort for nowt then !!!! 2015 4.4 AB
2nd Dec 2018 12:13am |
Stan you're absolutely right it's eight. Missed than from the inside, maybe two under the IC
2nd Dec 2018 1:36pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3689 |
https://dictionary.cambridge.org/dictionar...n-t-fix-it
2nd Dec 2018 2:06pm |
You say that Mike but here's a GIF mock up, might get you tempted?
2nd Dec 2018 2:15pm |
Spen King will be turning in his grave G reg 2.5VM Vogue Portofino red 1991- 1999
2nd Dec 2018 2:24pm |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
They are a good find John and would work well with the earlier non led lights. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
2nd Dec 2018 4:27pm |
2015 4.4 AB
3rd Dec 2018 1:19am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2314 |
LEDs use a driver IC so cutting into the strip wont work unless the drivers are next to the LEDs. The LED strips that can be cut have their drivers adjacent to the LEDs using 12V+/- rails down each side.
3rd Dec 2018 2:48am |
