Home > Maintenance & Mods (L322) > dynamic indicators
GGDR
This one on the bay: https://www.ebay.co.uk/itm/5-Step-Sequenti...:rk:7:pf:0
...is 5-steps.
We'd need 8 steps ideally. You could always combine a couple and use the 5-step I guess. Not great for the OCD.
Looking at this I think as per my last post it might be easier to take the original ribbon completely out and make up a new 'string' with new LEDs.
EDIT It's 12 LEDs like this:
Any suggestions on which LED's anyone?
. Cheers, Greg
Post #497251 1st Dec 2018 8:48pm
wow, you have been busy....why did LR make these lights so complicated Laughing
when you look at the light unit [fitted] you see 8 vertical rows so if using a five step module you could have a sequence of 3,2,1,1,1 maybe..
can the ribbon be spliced somehow greg?
@craig Thumbs Up
Post #497256 1st Dec 2018 9:57pm
GGDR
I've counted seven rows Stan.... (I could be wrong).
Not sure I'd be confident slicing into the ribbon. No idea though.
But on a safety item I'd want a super sound connection.
With ribbon then LED and ribbon then LED etc etc you'd end up with so many slices I'm thinking better and more reliable to make up a new 'sting' with new cable and new LEDs.
. Cheers, Greg
Post #497262 1st Dec 2018 10:07pm
makes sense re a new ribbon/cable...
i guess we'll be both out tomorrow counting them leds... Wink
craig mentioned that powerfuluk might be doing something. i wonder what that is, maybe a new ribbon thingy?
Post #497265 1st Dec 2018 10:16pm
thinking that if the rear light unit does have 8 vertical leds then a 4 step module would be best [2,2,2,2]
Post #497268 1st Dec 2018 10:26pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
https://www.ebay.co.uk/itm/2x-45cm-Car-LED...2443650408
Any good for what you are after lads? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #497280 1st Dec 2018 11:39pm
GGDR
Nah John the strip won't work.
We'll need 12 individual LEDs made up to fit the housing positions..
. Cheers, Greg
Post #497285 2nd Dec 2018 12:10am
dolph34
Thats my best googling effort for nowt then !!!! 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #497286 2nd Dec 2018 12:13am
GGDR
Stan you're absolutely right it's eight. Missed than from the inside, maybe two under the IC
 Cheers, Greg
Post #497317 2nd Dec 2018 1:36pm
Baltic Blue
https://dictionary.cambridge.org/dictionar...n-t-fix-it
I think you lads must be bored, looking for your next project Rolling with laughter Rolling with laughter
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #497323 2nd Dec 2018 2:06pm
GGDR
You say that Mike but here's a GIF mock up, might get you tempted?
. Cheers, Greg
Post #497325 2nd Dec 2018 2:15pm
Baltic Blue
Spen King will be turning in his grave Big Cry Big Cry G reg 2.5VM Vogue Portofino red 1991- 1999
Post #497326 2nd Dec 2018 2:24pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
They are a good find John and would work well with the earlier non led lights. Thumbs Up 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #497336 2nd Dec 2018 4:27pm
dolph34
Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #497384 3rd Dec 2018 1:19am
GraemeS
LEDs use a driver IC so cutting into the strip wont work unless the drivers are next to the LEDs. The LED strips that can be cut have their drivers adjacent to the LEDs using 12V+/- rails down each side.
Progressively lighting blinkers are unlikely to meet regulatory timing requirements when viewed from the extremities.
Post #497385 3rd Dec 2018 2:48am
