Home > Technical (L322) > Adaptive Dynamics Fault light
Page 7 of 9 <123456789>
OtleyDominic
Mine recently done
Post #461093 16th Dec 2017 11:12pm
Blencoe
United Kingdom 2011 Range Rover Vogue 4.4 V8 Baltic Blue
Once again you guys have saved the day, driving home my Adaptive Dynamics warning light pops up, uh-oh I thought. Parked, got iPad, looked up fullfatrr.com and 15 minutes later it’s fixed, broken wire front drivers side (right side in the UK). Thank you to everyone who contributes to this great site, Merry Christmas all.
Post #499417 22nd Dec 2018 1:42pm
appreciate the thanks... Thumbs Up
Post #499419 22nd Dec 2018 2:07pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Thanks for this write up -- quick fix indeed -- well actually I took the time to let some new pieces of cable in and solder (rather than using a straight through crimp as someone had done before) - and hey presto -- happy FFRR Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #508317 11th Mar 2019 7:05pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Well it happened to mine yesterday, this morning I took the cover off and sure enough the wire was brittle and broken. I made up a new lead using silicone wire (like whats used on test meter probes), inside some heatshrink sleeve and then some braided sleeve on the outside. Ran this back to the look, cut into it and remade the connections. All fine now.
Just one point many of you think these cables are static, theyre not, they turn with the steering hence the breaks.
J BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #517768 8th Jun 2019 11:05am
Range Rover L322
Just for completeness, here's the LR technical bulletin.
Post #556744 7th Jun 2020 12:30am
Range Rover L322
Ordered from Sophie.Alltoft@duckworth.co.uk
LR032839 - UPGRADE SUSPENSION ADAPTIVE DAMPER WIRING FOR RANGE ROVER L322 - 2009-2012 - GENUINE LAND ROVER
I really like Duckworth. Really helpful, fast turnaround and cheaper than the other Genuine LR stockists.
I'm only using them from now on.
Post #557341 11th Jun 2020 5:45pm
Range Rover L322
Also Top Tip is to use Shirinkable Solder Connectors - they are fantastic and much easier than soldering if you are out of practice...
https://www.amazon.co.uk/gp/product/B07TLL...&psc=1
Post #557342 11th Jun 2020 5:48pm
GGDR
My proper fix:
https://www.fullfatrr.com/forum/topic54413.html
. Cheers, Greg
Post #557343 11th Jun 2020 5:48pm
GGDR
OMG those connectors are genius
Never seen them but wow
. Cheers, Greg
Post #557344 11th Jun 2020 6:00pm
paulbrown22
United Kingdom 2011 Range Rover Supercharged 5.0 SC V8 Stornoway Grey
This alert popped up on my 2011 5.0 S/C on the way back from Newbury on Sunday, just as I got back into Poole. The longest journey the vehicle has done for 7-8 weeks now, beautiful as always aside from this minor surprise at the end!
Thankfully I'd read about it all on here many times, so I wasn't overly concerned, and assumed/hoped it would just be the usual broken wire in a front turret.
IID plugged in as soon as I got home which instantly pointed out the front right turret. I whipped that off, and yes, a clear break in one of the wires. I know Greg and others have posted fancier repairs, or using the complete LR replacement harness, but given this was the first time it's happened to my vehicle, I thought for now I'll just solder it up, and then decide what to do for if/when it goes next time, and order up some parts so I have them ready.
That was still easier said than done - my soldering iron seemed to be utterly dead, and Dad's ancient iron was barely hot enough to melt butter and didn't make a good join at all... So I gave up on having it fixed last night, removed the dodgy soldering as I wasn't happy with it at all, and ordered up a new iron on Amazon to arrive today. That was here by lunchtime, so I finished the repair tonight. All now seems to be working perfectly, at least for a couple of miles test drive.
Am now reading the various threads about alternative/longer term fixes, so I can stock up on supplies ready should it go again, or the other side suffer the same problem!
Post #560418 6th Jul 2020 11:32pm
DrRob
Paul - great to hear. Did the IID specifically say "front right" by any chance? Is that driver's or passenger's side? I get confused Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90
Post #560433 7th Jul 2020 7:58am
Baltic Blue
Rob,
I can’t remember the exact wording on the iid, but when mine broke it left me in no doubt that the fault was front passenger side.
Post #560434 7th Jul 2020 8:08am
DrRob
Thanks Mike. With the GAP being Canadian etc.. Whistle
I guess when the IID is VIN locked then it knows its a UK build Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #560436 7th Jul 2020 8:09am
paulbrown22
Yes, was very clear - just plain old "right" on mine, no confusion about drivers, passengers, etc!
The exact message was: "C110D-14 (2C) Front right damper solenoid - General electrical failure - circuit short to ground or open"
Post #560452 7th Jul 2020 9:46am
