Home > Technical (L322) > Adaptive Dynamics Fault light |
OtleyDominic Member Since: 01 Nov 2017 Location: Leeds Posts: 61 |
Mine recently done |
16th Dec 2017 11:12pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34935 |
appreciate the thanks... |
22nd Dec 2018 2:07pm |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1097 |
Thanks for this write up -- quick fix indeed -- well actually I took the time to let some new pieces of cable in and solder (rather than using a straight through crimp as someone had done before) - and hey presto -- happy FFRR Current: 2011 FFRR Vogue SE 4.4 TDV8
11th Mar 2019 7:05pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1462 |
Well it happened to mine yesterday, this morning I took the cover off and sure enough the wire was brittle and broken. I made up a new lead using silicone wire (like whats used on test meter probes), inside some heatshrink sleeve and then some braided sleeve on the outside. Ran this back to the look, cut into it and remade the connections. All fine now.
8th Jun 2019 11:05am |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 305 |
Just for completeness, here's the LR technical bulletin.
7th Jun 2020 12:30am |
Ordered from Sophie.Alltoft@duckworth.co.uk
11th Jun 2020 5:45pm |
Also Top Tip is to use Shirinkable Solder Connectors - they are fantastic and much easier than soldering if you are out of practice...
11th Jun 2020 5:48pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
My proper fix:
OMG those connectors are genius
11th Jun 2020 6:00pm |
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 350 |
This alert popped up on my 2011 5.0 S/C on the way back from Newbury on Sunday, just as I got back into Poole. The longest journey the vehicle has done for 7-8 weeks now, beautiful as always aside from this minor surprise at the end!
6th Jul 2020 11:32pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4245 |
Paul - great to hear. Did the IID specifically say "front right" by any chance? Is that driver's or passenger's side? I get confused Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
7th Jul 2020 7:58am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3685 |
Rob,
7th Jul 2020 8:08am |
Thanks Mike. With the GAP being Canadian etc..
7th Jul 2020 8:09am |
Yes, was very clear - just plain old "right" on mine, no confusion about drivers, passengers, etc!
7th Jul 2020 9:46am |
