Home > Technical (L322) > L322 Front Brake Disc Slot
netsonic Steve
United Kingdom 2002 Range Rover Vogue Td6 Epsom Green
Just fitted new front discs and pads, pattern parts........noticed this cut out in one disc. Contacted the supplier of the discs who contacted their manufacturer who confirms this is to Land Rover spec but they don’t know why its there ......any idea..........
Post #115254 28th Mar 2012 7:42pm
I think it indicates the minimum thickness you can run the disc down to before you need to change them.
Post #115255 28th Mar 2012 7:47pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
+1 Thumbs Up
Always been told that it is a waer indicator 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #115271 28th Mar 2012 9:02pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
I always assumed it was to balance them, but the minimum thickness sounds more likely Thumbs Up
Gone - Range Rover Supercharged 2006
Post #115272 28th Mar 2012 9:06pm
I think LR pinched the idea off BMW who have used the idea for a long time.
Post #115276 28th Mar 2012 9:20pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
BMW having owned LR after BAE and before Ford? Erm....so? Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #115278 28th Mar 2012 9:21pm
I thought it was for balancing. The disc's are cast then machined flat etc they would then be balanced. Or that's how I always thought it was. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #115308 28th Mar 2012 11:55pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Could settle it by measuring- the min thickness is in RAVE.
Post #115313 29th Mar 2012 7:27am
100% for balancing...
Craig Thumbs Up
Post #115315 29th Mar 2012 7:56am
I'd say balancing but it's a lot to take out and I doubt the disc would be that much out of balance
Wear sounds good but that's a lot of wear and leaves a pretty thin disc.
So really no scoobie doo. There is nothing that can't be fixed with a hammer😜😜
Post #115899 1st Apr 2012 9:43pm
resonance....so that the discs dont 'sing' when rotating.. ... - .- -.
Post #115939 2nd Apr 2012 10:13am
