Home > Technical (L322) > L322 Front Brake Disc Slot |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 |
I think it indicates the minimum thickness you can run the disc down to before you need to change them. |
28th Mar 2012 7:47pm |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
+1
28th Mar 2012 9:02pm |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 |
I always assumed it was to balance them, but the minimum thickness sounds more likely
28th Mar 2012 9:06pm |
I think LR pinched the idea off BMW who have used the idea for a long time. |
28th Mar 2012 9:20pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
BMW having owned LR after BAE and before Ford? Erm....so? Land Rover Addict
28th Mar 2012 9:21pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
I thought it was for balancing. The disc's are cast then machined flat etc they would then be balanced. Or that's how I always thought it was. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
28th Mar 2012 11:55pm |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1490 |
Could settle it by measuring- the min thickness is in RAVE. |
29th Mar 2012 7:27am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
100% for balancing...
29th Mar 2012 7:56am |
I'd say balancing but it's a lot to take out and I doubt the disc would be that much out of balance
1st Apr 2012 9:43pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34944 |
resonance....so that the discs dont 'sing' when rotating.. ... - .- -.
2nd Apr 2012 10:13am |
