![]() | Home > Technical (L322) > L322 Front Brake Disc Slot |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
I think it indicates the minimum thickness you can run the disc down to before you need to change them. |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
+1 |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
I always assumed it was to balance them, but the minimum thickness sounds more likely |
I think LR pinched the idea off BMW who have used the idea for a long time. |
BMW having owned LR after BAE and before Ford? Erm....so? Land Rover Addict
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
I thought it was for balancing. The disc's are cast then machined flat etc they would then be balanced. Or that's how I always thought it was. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1529 ![]() ![]() |
Could settle it by measuring- the min thickness is in RAVE. |
100% for balancing...
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8775 ![]() ![]() ![]() |
I'd say balancing but it's a lot to take out and I doubt the disc would be that much out of balance
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
resonance....so that the discs dont 'sing' when rotating.. ... - .- -.
