Home > Technical (L322) > Is this normal suspension behaviour?
Page 2 of 3 <123>
hoppy
England 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Meerbusch wrote:
First sign for the defect pressure sensor in the silver air-tank under the right side of the underbody..., and also for the compressor pressure under 13,7 atü...., because the ECU, the sensor and the front ventil work together only with full pressure
regards from germany
thanks for that...GRIM REAPER......
its normal...happens to mine every morning as my drive is not level..
like evryone else has said,, no need to worry...unless your the grim reaper from sunny germany free use of "RSW" all comms to anyone nearby
Post #127922 27th Jun 2012 11:04am
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Rob2529 wrote:
Aren't you a ray of sunshine this morning. Rolling with laughter
Do you work for Wabco meerbusch?
Why are you all being personally offensive to someone who has obviously tried to give a polite technical answer in his second language? While I don't agree that it's the best thing you want to hear, or indeed it's 100% correct, I don't think it's fair to attack him personally for it.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #127925 27th Jun 2012 11:27am
Martin
Site Admin
Agreed - unnecessary hoppy, no need to be impolite to other forum users.
Post #127926 27th Jun 2012 11:31am
@meerbusch Appologys if any offence caused. Not meant in that mannor. The question about Wabco was a genuine one as you seem to have alot of knowledge about the system and it's design. They seem very tight lipped with info when I contacted them about the compressor pistonrings.
@allseeingpie wasn't a personal attack. Thought the smiley at the end gave that away. Will make any jokes/sarcasm more obvious. Happy? Rolling with laughter That was sarcasm! Whistle Laughing [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #127942 27th Jun 2012 12:38pm
TheAllSeeingPie
Sorry Rob, I'd obviously got my knickers in a twist after reading Hoppy's post Rolling with laughter No offence meant.
Post #127946 27th Jun 2012 1:20pm
Having read this post through I think you may be doing Meerbusch a bit of a dis-service.
I think he is a bit closer to the mark than some of you may wish to believe.
The purpose of the suspension is to maintain the car level relative to the surface it is sitting on whichever of the settings it happens to be in.
It is not intended to keep the car level at all times ie driving up or down a hill Smile, or on a sloping driveway.
If your car settles overnight on a sloping driveway (front to rear slope) such that it pumps itself level in the morning, it strikes me you have a small leak on the system. Much as Meebusch indicates.
If you car is parked on un-even ground the car suspension will adjust to the optimum level for the 4 wheels to maintain body height relative to the wheels but if your car is parked on sloping un-even ground the car will still be on a slope.
The traffic light situation could also be attributed to a small system leak insofar as the car braking could cause a pressure increase in the front air bags, which if they have a small leak could increase the rate of leakage until the increased load is taken off the bags in which case when the car came to a standstill the bags would need blowing up to height again.
I probably haven't got all this correct but you may wish to think about it and reply as necessary.
Suffice to say, my non too special car has never performed any of the above described suspension antics (yet) and if it did it's likely I would be out with the soap solution bottle.
I certainly wouldn't consider it normal.
Discuss Very Happy
Post #127950 27th Jun 2012 1:48pm
my 2pence worth,
mine does the same , sometimes after hard braking , sometimes it just does it...i'm pretty certain i have no leaks as the suspension works without a hitch.
the comments made by hoppy and rob are pretty tame compared with some comments on the forum and to me are non offensive .
meerbusch probably does know what he's talking about as he specialises in repairing the compressors as commented in previous posts where he has tried to sell his services.. ... - .- -.
Post #127952 27th Jun 2012 1:59pm
No leaks in mine either having tested extensively at standard and off road height. I just put the behaviour down to the vagaries of the system as it adjusts itself to suit conditions, especially after automatically changing heights (motorway to standard). Meerbusch does have a good point though Smile .
Post #127954 27th Jun 2012 2:02pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
All 4 of mine have done/do this, and two of those were brand new from the dealer with zero miles. Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #127958 27th Jun 2012 2:16pm
rads
2005 Range Rover Vogue SE Supercharged Tonga Green
To the OP.
Completely normal.
The car was level.
You got in, drivers side corner went down.
Car then self leveled, and from your POV front of the car went up.
How much depends on how much of a fat b*st*rd you are.
Mine ALOT.
Wink
HTH
David
Post #127983 27th Jun 2012 4:02pm
hoppy
It was NOT meant to be impolite or a personal attack... purely a bit of FUN..
however if my comments offended anyone then i offer my sincere apologies,,
maybe i am better keeping my warped sense of humour to myself in future free use of "RSW" all comms to anyone nearby
Post #127989 27th Jun 2012 4:21pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Wink) no problem, I am not unhappy about the special posts to my person, it is normal..., but believe me: here in germany the Range Rover is a car which is not often to see, in GB there are the Range Rovers like at us the Mercedes ML. Therefore the german official dealers press out the customers like citrons..., and I work since 35 years with cars, BMW, Mercedes and since 14 years I only drive Range Rover, because it is the best car ever, and especially the LM has a good technic to repair. But now the official dealers begin to work with my parts, because the customers, who have RR about 6 years old, have not enough money for repairs like new keys for 230,-Euros, or gearboxes for 7.500,-Euros, or compressors for 800,-Euros, or steering-colums for 2.000,-Euros only because of a small broken part, which I construct in a little serie, or with problem of the empty batterie, and, and, and..., and to the complex thema EAS, it is so easy..., WABCO doesn´t give ANY information to the dealership, therefore I bought with the help of company Mercedes-Benz about 100 new compressors without the electro-motor, and why it is so bad, that I want to earn a little money, and HELP the other drivers with a repair for good price...?
Many regards from germany, Meerbusch
Post #128341 29th Jun 2012 12:01pm
Dolphinboy
Gut gesagt Meerbusch. Keine Angst vor grossen Tieren Jungs! Thumbs Up
Post #128345 29th Jun 2012 12:15pm
Vorsprung durch Technik ... - .- -.
Post #128346 29th Jun 2012 12:18pm
WTF has 'big animals to do with the thread Dolphinboy? Shocked
Post #128349 29th Jun 2012 12:22pm
Page 2 of 3 <123>
