Home > Technical (L322) > Help!!! Screeching on acceleration... Any ideas?
Lloyd Barnes
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Set off for work this morning and got about 30 miles when suddenly starting getting a loud screeching noise from drivers side front suspension. Big Cry Only happens when I accelerate, when at cruise/braking/very gentle acceleration it goes. Harder you accelerate, the worse the noise gets. Only happens under load, you can rev the engine at standstill and its fine.
Have just got back home after a very careful drive, and whizzed the wheel off. Nothing obvious to see, brakes aren't binding or unduly hot. No messages on dash.
I grabbed my Iphone and made a quick vid on the way home as I thought it would be useful to get some advice. Its uploading on Youtube now so I'll add a link when its finished.
Tried searching but nothing obvious, anyone had anything similar happen? Debating whether to take it to local 4x4 Indy or Land Rover dealer in Shrewsbury, but they are 40 minutes drive away plus there is the cost factor! If I know what it could be I'd rather let the Indy do it (or do it myself if practical). Help!!! Sad Lloyd Barnes
Current
Crendon 427 Sideoiler Cobra in build... 7 litres of madness!
Gone
2008 TDV8 Vogue - Black with Ivory/Grand Black Lacquer
2008 VW Touareg 3.0Tdi
6.3litre Dax Cobra - 12.34 Second 1/4mile at 114mph Smile
Post #131533 17th Jul 2012 6:47am
Lloyd Barnes
Screeching Video!
Here's the video I took on the way home. I initially thought it was when I went around a corner, but after a while it was clear that it was only on acceleration.
&feature=youtu.be Lloyd Barnes
Current
Gone
Post #131539 17th Jul 2012 7:13am
sticking brake caliper?..is the wheel hot after a run. ... - .- -.
Post #131543 17th Jul 2012 8:07am
Sounds like a belt or a bearing away in the engine compartment. I take it the same noise happens wether you are doing 20 or 60 and accelerating? Previously..
Post #131547 17th Jul 2012 8:15am
Lloyd Barnes
Checked the brake caliper and no signs of it binding, brakes discs warm but not hot after a run. Yes, its not speed dependant, but load on the engine.
I've just popped it down to a local garage in the village where I know the owner. He's saying take it to LR dealer but one thing we noticed is that one of the injectors is leaking diesel. Not sure if its related. Lloyd Barnes
Current
Gone
Post #131559 17th Jul 2012 9:06am
injector leaking diesel onto one of the belts maybe. ... - .- -.
Post #131561 17th Jul 2012 9:13am
simon1233
Sounds like a belt noise to me, if you have an injector spraying diesel around the engine compartment it could have got onto one of the belts - everything is quite tightly packaged on the TDV8
Post #131564 17th Jul 2012 9:21am
Lloyd Barnes
I've stuck my head back under, the fuel seems mainly to be leaking down and backwards, I don't think its getting to the belts although its hard to tell there's so much gubbins under there!
I'm going to bite the bullet and call the local LR dealer and get it booked in. I'll let you know how I get on. Lloyd Barnes
Current
Gone
Post #131570 17th Jul 2012 9:31am
Have you looked at your turbo hoses for damage or loose clips?
Post #131577 17th Jul 2012 10:28am
Lloyd Barnes
Well the LR dealer can't even see it until Friday so I'm taking it in my garage and taking it apart. It will probably never work again! Laughing Lloyd Barnes
Current
Gone
Post #131589 17th Jul 2012 11:29am
Can you get your hand to the belt? Obviously when it's not running! How much free movement is there in the belt? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #131591 17th Jul 2012 11:45am
Lloyd Barnes
No obvious signs of damage to hoses, although its not easy to be 100% sure lying on your back.
It does seem strange it would suddenly start leaking diesel at exactly the same time the noise appears. However it seems nigh on impossible to get to the injectors. There's a metal cover plate over them which I've unbolted but I don't think is coming off without removing what looks like the anti lock brake control?
Belts seem tight enough. Now I know why I love old cars so much! Simple beasties to get to and fix when they break! Lloyd Barnes
Current
Gone
Post #131601 17th Jul 2012 1:08pm
Lloyd Barnes
Well I found a Land Rover indy that can look at it earlier. Will let you know the outcome. Fingers crossed its not too expensive! Lloyd Barnes
Current
Gone
Post #131607 17th Jul 2012 1:43pm
Rolo
United Kingdom 2012 Range Rover Vogue SE TDV8 Orkney Grey
Sounds more like an idler pulley or bearing somewhere to me ?
best of luck in finding it Thumbs Up
Post #131609 17th Jul 2012 1:45pm
Could it be tranny related, maybe a bearing in the tc, or if it sounds like its coming from the front maybe something in the front diff. There is nothing that can't be fixed with a hammer😜😜
Post #131644 17th Jul 2012 5:03pm
