![]() | Home > Technical (L322) > Help!!! Screeching on acceleration... Any ideas? |
| Lloyd Barnes Member Since: 21 Apr 2011 Location: Shrewsbury Posts: 181
Here's the video I took on the way home. I initially thought it was when I went around a corner, but after a while it was clear that it was only on acceleration.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885
sticking brake caliper?..is the wheel hot after a run. ... - .- -.
| Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700
Sounds like a belt or a bearing away in the engine compartment. I take it the same noise happens wether you are doing 20 or 60 and accelerating? Previously..
Checked the brake caliper and no signs of it binding, brakes discs warm but not hot after a run. Yes, its not speed dependant, but load on the engine.
injector leaking diesel onto one of the belts maybe. ... - .- -.
| simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650
Sounds like a belt noise to me, if you have an injector spraying diesel around the engine compartment it could have got onto one of the belts - everything is quite tightly packaged on the TDV8 |
I've stuck my head back under, the fuel seems mainly to be leaking down and backwards, I don't think its getting to the belts although its hard to tell there's so much gubbins under there!
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
Have you looked at your turbo hoses for damage or loose clips? |
Well the LR dealer can't even see it until Friday so I'm taking it in my garage and taking it apart. It will probably never work again! |
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470
Can you get your hand to the belt? Obviously when it's not running! How much free movement is there in the belt? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
No obvious signs of damage to hoses, although its not easy to be 100% sure lying on your back.
Well I found a Land Rover indy that can look at it earlier. Will let you know the outcome. Fingers crossed its not too expensive! Lloyd Barnes
| Rolo Member Since: 11 May 2011 Location: UK Posts: 852
Sounds more like an idler pulley or bearing somewhere to me ?
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
Could it be tranny related, maybe a bearing in the tc, or if it sounds like its coming from the front maybe something in the front diff. There is nothing that can't be fixed with a hammer😜😜
| All times are GMT |
