Home > Maintenance & Mods (L322) > Door cards vibrating when listening to music
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Probably caused by excessively loud music on the motorway after a stressful day, but my door cards seem to rattle when listening to music. Apart from the obvious solution of turning the music down, is there a way to tighten up the fitting? Alternatively how do you remove the cards so I can put some sound proofing in?
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #131515 16th Jul 2012 9:21pm
simon1233
When I got mine last year I had a similar fault, pop the offending door card off and tighten the bolts on the speakers. Thumbs Up
Can't tell you how, the dealer did mine...
Post #131522 16th Jul 2012 11:00pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
My 'door lock pop ups' rattle Sad Really don't want to pop the cards off just for that - after owning four of the things I never had this before! Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #131523 16th Jul 2012 11:04pm
door cards off and tighten everything you can see... ... - .- -.
Post #131546 17th Jul 2012 8:11am
Powerfull Uk do a good video about how to take door cards off. its dead easy so dont be affraid. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #131671 17th Jul 2012 8:10pm
Couldnt get mine off Sad
Followed video, couldnt get the top edge to release. Didnt want to force it. Do you need to? There is nothing that can't be fixed with a hammer😜😜
Post #131672 17th Jul 2012 8:18pm
daveo
you do have to give a bit of a tug,lift it at the door look end first. V8 facelift Range Rover Autobiography 22" wheels.
Post #131676 17th Jul 2012 8:32pm
Turbo Tony
If you're taking the door card off, I'd be tempted to give any parts that vibrate a layer of Dynamat sound deadening material.
(flashing tape from DIY outlets is c cheap alternative, but will usually require more layers) Researching my first Range Rover purchase
Post #131856 18th Jul 2012 4:36pm
