Home > Technical (L322) > Removing tow bar with no key?
Googsy
I know when I had a Disco there was a way to remove towbar without key! Just wondering if towbar on FFRR can be removed without key as the one i received with mine has been lost ! Obviously im concious there maybe crooks about so if possible please can you PM me . Thanks Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #132521 23rd Jul 2012 3:16pm
best way is to undo the bolt which holds the 2 pieces and then you're left with a 2'' square hole..... ... - .- -.
Post #132523 23rd Jul 2012 3:33pm
Googsy
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #132526 23rd Jul 2012 3:48pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
If it's the detachable towbar then you're best keeping it in the boot when not in use. Mine came with a broken key in the lock so I just removed it myself using rudimentary tools in not very long at all. Shame I can't get a replacement lock ...
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #132549 23rd Jul 2012 5:39pm
Knips
United Kingdom 2017 Range Rover Vogue SE SDV8 Santorini Black
I have a similar issue with the key snapped off in the towbar lock. I removed the bolt (green arrow) and applied moderate force to try and extract the towbar assembly from the square receiver as Stan mentioned.
Can some one confirm please that with the towbar "locked on" I should be able to remove the assembly this way? .. or is there a knack?
Post #132597 23rd Jul 2012 10:55pm
i took mine off this way..plenty of wd40 and bang with hammer.. ... - .- -.
Post #132621 24th Jul 2012 9:48am
T111RDY
Scotland 2002 Range Rover Vogue 4.4 V8 Java Black
Me too - a big hammer! l:OolΞΞΞΞΞΞloO:l
2002 4.4 Vogue Java Black
Post #132626 24th Jul 2012 10:07am
I've read on here the WD40/Penetrating fluid and hammer technique works or,
Low range, 1st, tied with some strong material to a substantial tree, with the mrs or such like at the helm while you tap it with a hammer it should just drop out as the car goes forward, or bounce back toward the tree a little Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #132638 24th Jul 2012 10:43am
When you put the receiver into the square hole give the square hole and the receiver a thick coating of grease before inserting.
It doesn't stick then. Idea
Doesn't help getting a stuck one out though. Laughing
Post #132648 24th Jul 2012 11:45am
Knips
Thanks all, looks like I need a bigger Sheffield screwdriver!
Post #132659 24th Jul 2012 12:43pm
Andy
Theres a blanking plug for the square hole when you remove the tow bar, so it looks nice and tidy 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #133649 30th Jul 2012 8:51pm
but the plug is bright red [mine was] ... - .- -.
Post #133658 30th Jul 2012 9:35pm
T24RES
This is the plug Stan
Post #133661 30th Jul 2012 9:45pm
now that doesn't look to bad ian, mine was bright red and stood out like a sore thumb.. ... - .- -.
Post #133663 30th Jul 2012 9:52pm
T24RES
IIRC it was a fiver from the stealer.
Post #133665 30th Jul 2012 9:56pm
