Home > Technical (L322) > Removing tow bar with no key? |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
I know when I had a Disco there was a way to remove towbar without key! Just wondering if towbar on FFRR can be removed without key as the one i received with mine has been lost ! Obviously im concious there maybe crooks about so if possible please can you PM me . Thanks Present :2008 TDV8 HSE
23rd Jul 2012 3:16pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34943 |
best way is to undo the bolt which holds the 2 pieces and then you're left with a 2'' square hole..... ... - .- -.
23rd Jul 2012 3:33pm |
23rd Jul 2012 3:48pm |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 |
If it's the detachable towbar then you're best keeping it in the boot when not in use. Mine came with a broken key in the lock so I just removed it myself using rudimentary tools in not very long at all. Shame I can't get a replacement lock ...
23rd Jul 2012 5:39pm |
Knips Member Since: 01 Oct 2011 Location: United Kingdom Posts: 70 |
I have a similar issue with the key snapped off in the towbar lock. I removed the bolt (green arrow) and applied moderate force to try and extract the towbar assembly from the square receiver as Stan mentioned.
23rd Jul 2012 10:55pm |
i took mine off this way..plenty of wd40 and bang with hammer.. ... - .- -.
24th Jul 2012 9:48am |
T111RDY Member Since: 21 May 2012 Location: Dunbar Posts: 187 |
Me too - a big hammer! l:OolΞΞΞΞΞΞloO:l
24th Jul 2012 10:07am |
I've read on here the WD40/Penetrating fluid and hammer technique works or,
24th Jul 2012 10:43am |
Thanks all, looks like I need a bigger Sheffield screwdriver! |
24th Jul 2012 12:43pm |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2929 |
Theres a blanking plug for the square hole when you remove the tow bar, so it looks nice and tidy 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
30th Jul 2012 8:51pm |
but the plug is bright red [mine was] ... - .- -.
30th Jul 2012 9:35pm |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
This is the plug Stan
30th Jul 2012 9:45pm |
now that doesn't look to bad ian, mine was bright red and stood out like a sore thumb.. ... - .- -.
30th Jul 2012 9:52pm |
IIRC it was a fiver from the stealer. |
30th Jul 2012 9:56pm |
