Home > Technical (L322) > handbrake light remains on
goldsax
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
after applying the handbrake and switching the engine off, removing the keys .the hand brake light remains on.
even after alarming the FF the light reamains on for 10-20 minutes.
is this normal? as i cannot recall this happening before.
2007 TdV8 3,6
cheers
Post #133549 30th Jul 2012 1:14pm
not sure about that light but the range does take about that time to power every thing down...
Post #133556 30th Jul 2012 1:51pm
Googsy
mine does the same and disappears after a while. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #133571 30th Jul 2012 2:24pm
goldsax
reasurence in numbers..... Smile
puts my mind at rest..
Post #133574 30th Jul 2012 2:33pm
paneldamage
I have the opposite problem; my handbrake warning light has never worked, nor the seatbelt warning. I keep meaning to find out why....
Post #133677 30th Jul 2012 11:16pm
Bob the B
United Kingdom 2004 Range Rover Vogue Td6 Santorini Black
I have the same problem as paneldamage.
Tried looking with me RAC but with no luck Sad
Post #133679 30th Jul 2012 11:54pm
seat belt warning can be turned off/on via a method of inserting the belt a certain amount of times http://www.fullfatrr.com/forum/topic234.ht...lt+warning ... - .- -.
Post #133690 31st Jul 2012 8:19am
Bob the B
Tried that Stan but it didnt seem to work Sad
I have a pre touch screen so dont know if this makes a differance Confused
Post #133848 31st Jul 2012 10:56pm
it should work BOB, sometimes you need to do the procedure a few times . ... - .- -.
Post #133877 1st Aug 2012 10:44am
Bob the B
Will try when I next get time Thumbs Up
Post #133922 1st Aug 2012 1:41pm
stu
yes mine is the same, light stays on for long time after i have left the car. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #134406 5th Aug 2012 8:23am
