![]() | Home > Technical (L322) > handbrake light remains on |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35805 ![]() ![]() |
not sure about that light but the range does take about that time to power every thing down... |
mine does the same and disappears after a while. Present :2008 TDV8 HSE
goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196 ![]() ![]() ![]() |
reasurence in numbers..... |
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 ![]() ![]() |
I have the opposite problem; my handbrake warning light has never worked, nor the seatbelt warning. I keep meaning to find out why.... |
Bob the B Member Since: 10 Jun 2011 Location: Newcastle upon Tyne Posts: 163 ![]() ![]() ![]() |
I have the same problem as paneldamage.
seat belt warning can be turned off/on via a method of inserting the belt a certain amount of times http://www.fullfatrr.com/forum/topic234.ht...lt+warning ... - .- -.
Tried that Stan but it didnt seem to work |
it should work BOB, sometimes you need to do the procedure a few times . ... - .- -.
Will try when I next get time |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
yes mine is the same, light stays on for long time after i have left the car. Current: TDV8 (3.6) RRS HSE
