![]() | Home > In Car Electronics (L322) > IPOD connected to aux in rear ents system? |
AMD Member Since: 16 Jul 2010 Location: The South Posts: 811 ![]() ![]() |
That's the best it will be without the sound being amplified between the iPod and Aux in.
perroverde Member Since: 08 Sep 2012 Location: Lancashire Posts: 61 ![]() ![]() ![]() |
Thanks - i have been looking for a thread as figured it must be a common complaint - still havent found it though! |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8061 ![]() ![]() ![]() |
Is it pluvgged into the headphone socket or the Apple connecter ?
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2068 ![]() ![]() ![]() |
Alister
Bantam Member Since: 20 Feb 2012 Location: Cheshire Posts: 27 ![]() ![]() |
Volume is low if you use the headphone out socket (3.5mm), get a cable with the standard Apple docking connector cable and it works fine, with much increased volume:
Sorry - missed this part too - http://www.ebay.co.uk/itm/Double-RCA-Phono...4a9bc94218 Works well - I just stick the iPod in the ash tray and pick it up if I need to use the controls, but the volume is the same as the CD or radio |
So this should be good then?
As long as you don't need to use it with the iPhone 4 or later, I'd say that's got to be the way to go - it's all done for you - good find |
Sorted. I now have loud music. And charge.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3926 ![]() ![]() ![]() |
I've got a 4S and it works with one of them splitter cables - charges and sound is fine.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Just purchased a bluetooth dongly thing which plugs into the rear aux.
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
Does the bluetooth dongle thing stop it from tethering the phone? I can't say I've had any issues with a normal 3.5mm jack to jack cable :/ |
Still seems to tether the phone.
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
where did you get your bluetooth dongly thing from?
