Home > In Car Electronics (L322) > IPOD connected to aux in rear ents system?
perroverde
United Kingdom 2007 Range Rover SE TDV8 Java Black
I have just bought a TDV8 SE with the rear entertainment system. i tried plugging my ipod into the 'aux' socket, which works but the volume is very low. Is this normal/can it be adjusted? i can't see any reference in the manual. I have turned the ipod volume to max.
Any guidance much appreciated!
Thanks
Post #140234 9th Sep 2012 9:45am
AMD
That's the best it will be without the sound being amplified between the iPod and Aux in.
There is a thread somewhere that discusses it. stan will be along soon with the details. Current MY2020
Gone: 1 x L405 and 2 x L322's
Post #140235 9th Sep 2012 9:51am
perroverde
Thanks - i have been looking for a thread as figured it must be a common complaint - still havent found it though!
Post #140238 9th Sep 2012 10:00am
Is it pluvgged into the headphone socket or the Apple connecter ?
Mine is plugged into the Apple connecter and works just fine.
I have one that looks like this -
http://www.ebay.co.uk/itm/Gold-RCA-Composi...3a76683599
and one of these -
http://www.ebay.co.uk/itm/1-5m-3-5mm-Jack-...25648d4248
Then just add this and you're charging too -
http://www.ebay.co.uk/itm/7dayshop-Univers...3cc9058f32
Post #140239 9th Sep 2012 10:10am
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
Alister
How does that work then?
You're iPod lead has male phono's and so does the 3.5mm jack
Post #140262 9th Sep 2012 1:43pm
Bantam
2007 Range Rover Vogue SE TDV8 Java Black
Volume is low if you use the headphone out socket (3.5mm), get a cable with the standard Apple docking connector cable and it works fine, with much increased volume:
Something like this:
http://www.ebay.co.uk/itm/Dock-Connector-t...2571925e8b
Then turn up the volume and get yourself some of these: Laughing
http://www.ebay.co.uk/itm/20-x-Classic-Sof...4602d0365d
Post #140278 9th Sep 2012 4:03pm
nbunney wrote:
Alister
Sorry - missed this part too -
http://www.ebay.co.uk/itm/Double-RCA-Phono...4a9bc94218
Works well - I just stick the iPod in the ash tray and pick it up if I need to use the controls, but the volume is the same as the CD or radio
Post #141245 15th Sep 2012 12:18pm
nbunney
So this should be good then?
http://www.ebay.co.uk/itm/190476062730?ssP...1423.l2649
Post #141266 15th Sep 2012 2:34pm
As long as you don't need to use it with the iPhone 4 or later, I'd say that's got to be the way to go - it's all done for you - good find Thumbs Up
Apple changed the charging for the iPhone 4 and all of the old cables no longer work - so the above should be fine even for the audio as long as you don't need to charge it.
Post #141350 16th Sep 2012 10:47am
perroverde
Sorted. I now have loud music. And charge.
Thank you guys.
Post #142844 24th Sep 2012 11:01pm
supershuttle
I've got a 4S and it works with one of them splitter cables - charges and sound is fine.
Cheap bur definately cheerful - a bit like me Thumbs Up Geoff
Post #143415 27th Sep 2012 10:48pm
Just purchased a bluetooth dongly thing which plugs into the rear aux.
Can stream music to it from iphone piece of peeS. No charging tho.
Was thinking of putting an auxsocket in the centre box near then i can put it in there and charge it with no wires showing. There is nothing that can't be fixed with a hammer😜😜
Post #143614 29th Sep 2012 8:03am
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Does the bluetooth dongle thing stop it from tethering the phone? I can't say I've had any issues with a normal 3.5mm jack to jack cable :/
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #143679 29th Sep 2012 3:14pm
Still seems to tether the phone.
Have one of the cables as well. Neither is a perfect solution.
Maybe a case of an ipod kit from dan Cool There is nothing that can't be fixed with a hammer😜😜
Post #143689 29th Sep 2012 5:10pm
stu
where did you get your bluetooth dongly thing from?
luv techy speak.. Laughing Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #143778 30th Sep 2012 2:31pm
