![]() | Home > In Car Electronics (L322) > TV Arial on a 2007MY Supercharged ... |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
Anyone know where it is? Apparently there is a fault with it (IIDTool) and also it gets jittery reception. |
Yes Side rear Windows and rear window.
So if the arial does turn out to be |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
i would check the connections first, might have oxidation causing the error. ... - .- -.
Well hopefully tomorrow is the day I fit the Seat Heat/Cooling ECU, so I'll have a look at the connections at the same time. I assume all the bits are on show and I don't have to go digging to find them? |
My money (not that i have a lot of it ;() is on connections. Time, humidity and electrons have done their destructive work so it is highly likely that you have some issues with corrosion. Just undo all the connections, clean them, spray them with contact cleaner and see if that resolves the issues. MY 2010 5.0 SC Galway green and sand interior!!
