Home > Technical (L322) > Searching for thread: petrol RR w park heat retrofit - fault
SteveMFr
Site Sponsor
Does anyone remember this? I vaguely remember a thread about a petrol RR (might have been an SC) with a park heater retrofitted that was throwing a fault due to the engine being warm when the ECU actually expects a cold start. ( Rolling Eyes stupid RR thinks too much)
Couldn't find it using search Embarassed
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #154061 28th Nov 2012 12:38pm
http://www.fullfatrr.com/forum/topic12897....ing+heater
this one? ... - .- -.
Post #154064 28th Nov 2012 12:52pm
SteveMFr
Site Sponsor
Hi Stan,
Nope - it was much longer ago. At least a year poss even 2 or 3.
Thanks anyway, tho. Thumbs Up
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #154065 28th Nov 2012 1:05pm
flipping 'eck Steve that'll be hard to find... Laughing
btw , item sent. Wink ... - .- -.
Post #154084 28th Nov 2012 2:59pm
On that hard to find issue.....
Should searches not be ordered in relevance rather than age of post...(Martin) Very Happy
Post #154086 28th Nov 2012 3:05pm
hopefully its one of these ....
http://www.fullfatrr.com/forum/topic1324.h...ing+heater
http://www.fullfatrr.com/forum/topic3586.h...ing+heater ... - .- -.
Post #154088 28th Nov 2012 3:07pm
SteveMFr
Site Sponsor
Neither of those either Stan. But that second thread was interesting. Really sounds like I knew wtf I was talking about Rolling with laughter
Thanks for your help, tho. I'm pretty sure that I know where the prob lies: this is an SC that throws a fault when the retrofitted park heater is run as the motor is expecting a cold start and suddenly the ECM finds a warm motor - so it thinks the temp sending unit or the ambient air temp sending unit in the MAF is bad.
Christian and I had a discussion a while back about the function of the water changeover valve for the FBH. I said it was for comfort - first you heat the interior and then the motor - and Christian said that he had read on topix that it was to avoid cold start issues with the motor - the motor is simply not pre-warmed.
Seems we were both right: on the BMW motored RRs the function is for comfort the way I described and, when the Jag motors were installed and started throwing faults, LR just solved the prob quick and dirty by leaving the changeover valve closed during park heat and leaving the motor cold. Stupid IMHO. Confused
This also means that we have to let TDV8 owners know that they need to install the changeover valve if they activate the park heat function with the IIDTool or they may throw faults. Embarassed
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #154205 28th Nov 2012 10:11pm
Martin
Site Admin
How is a computer supposed to determine relevance? Unless you have a massive bank of servers and are called Google or Yahoo it's virtually impossible Big Cry
Post #154232 28th Nov 2012 11:56pm
SteveMFr
Site Sponsor
I dunno, tho, seems to me that search works better on D3.co..uk than here or at RRS... Possible?
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #154256 29th Nov 2012 7:36am
tbh i dont have a problem with the search...as long as you use the quotation marks then you should get what you want..you do need to sometimes put in a variation of what you are searching, for instance, fbh or fuel burning heater or park heater might bring up different threads... ... - .- -.
Post #154262 29th Nov 2012 9:13am
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Well some FFRR / Land Rover synonym population might help at least: http://www.phpbbdoctor.com/blog/2007/03/06...-synonyms/
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #154274 29th Nov 2012 9:45am
Martin
Site Admin
RRS/D3 search and FFRR search the same.
Do read the search help as using plus signs can help a lot Smile
Post #154281 29th Nov 2012 10:12am
bizzybus
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
PRE HEATER FAULT
Hi, Anyone tell me why my pre heater when used is dumping fuel onto my driveway (wife going ape) Sad
Post #154337 29th Nov 2012 1:21pm
