Home > Technical (L322) > Engine heat drops with fan speed.
Page 2 of 3 <123>
cold_n_wet
Have you had your webasto checked to see if is working ?
Post #164963 15th Jan 2013 4:34pm
Norway
Norway 2003 Range Rover Vogue Td6 Adriatic Blue
No i have not, but The webasto ony accelerate The heating, right? It should not have anything to do With The fan speed, nor Engine rom. -03V td6
-72 Cadillac Coupe DeVille 7,7liter.
Post #164975 15th Jan 2013 5:09pm
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
47p2 wrote:
How to check a viscous fan Click
Or alternatively if you can grab it and stop it with your hand its fine, if you have no fingers left its not!!! One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #164976 15th Jan 2013 5:15pm
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
don't think its my viscous - tomorrow i will have a look whist the engine is running- temp gauge indication drop now when at idle. But returning from Antwerp just now steady guage steady in upright position -All very confusing.
edit to ask - if one actually looks at the viscous with the mark1 eyeball whilst the engine is 'warm' and running would you see it turning?? - and what about the electric fan forward of the radiator?
Post #165042 15th Jan 2013 7:40pm
DavidP
Back to Joe90's post earlier where he asked is there some turning of the viscous fan. Just returned home and parked up for 10mins, temp gauge slap bang in the middle - no movement. Just started up to move back and temp gauge at 1/4, ok its -7 at the moment, FBH activates. Using the opportunity to check the fansd, i left it in idle, temp still at 1/4, FBH on, peering through the grill 'electric' fans still, but the viscous fan was turning - not with great gusto but all the same turning. Wondering if the turning is normal?. Bit long winded i know but......
Post #165503 17th Jan 2013 7:51pm
jim2RRs
United States 2005 Range Rover HSE 4.4 V8 Chawton White
ebajema wrote:
If you mean the central vents in the dashboard are blowing cold air, that is possible. Underneath the vents, right in the middle there is a little wheel with red and blue dots on it. It allows you to separately from the rest blow warm or cold air in. Dial that wheel to red and there should be warm air coming out.
The cable connects to this little wheel using a completely crappy bit of plastic.
Mine broke, on the cold setting, of course.
Remove the vent piece to see the plastic crap.
That made me sad. Jim
2000 NAS HSE
2005 NAS HSE
Post #165534 17th Jan 2013 9:47pm
JohnnyDangerous
It will turn a bit with the engine, it locks more as the motor gets hotter. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #165536 17th Jan 2013 9:52pm
DavidP
Thanks Johnny. I had a text exchange with the UK based [Hailsham] Chief Engineer last night. He said the same, some turning with engine in idle. Did the engine off test, fan turns both ways with a little resistance. So it's back to the drawing board.
Post #165574 18th Jan 2013 6:43am
Norway
Hi,
Iam awaking this thread as its winter and the car suffers from not getting hot. You know, as long as iam pressing the engine it gets worm, but as for driving normaly, downhill, with High rpms it the heat just drops.
Some good feedback is as allways appreciated. -03V td6
Post #224862 23rd Nov 2013 11:27pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Could the thermostat be stuck open? 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #224894 24th Nov 2013 8:15am
Sounds like the thermostat to me too. Cheap place to start Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #224897 24th Nov 2013 8:25am
Take the viscous fan off for a week and see what happens.
You don't need to worry about the engine over heating, all diesel engined cars are significantly over-cooled in winter temperatures by way of there design and operation. They run cool for a lot of the time hence the fitting of FBH.
Post #224908 24th Nov 2013 9:40am
Norway
HI, The main thermostat was changed, is there a second one.
yeah, the viscose has to go.
Thx -03V td6
Post #225006 24th Nov 2013 8:52pm
Norway
Is there step by step guide on dismantling the viscose fan. -03V td6
Post #225011 24th Nov 2013 9:19pm
wealy
Do NOT run your rangy without the vicious fan.... You will blow your cylinder head gasket or crack your head
Big Cry
Post #225019 24th Nov 2013 9:53pm
Page 2 of 3 <123>
