Home > Technical (L322) > Engine heat drops with fan speed. |
cold_n_wet Member Since: 07 Jan 2013 Location: Norway Posts: 3 |
Have you had your webasto checked to see if is working ? |
15th Jan 2013 5:34pm |
Norway Member Since: 09 Dec 2012 Location: Høvik Posts: 123 |
No i have not, but The webasto ony accelerate The heating, right? It should not have anything to do With The fan speed, nor Engine rom. -03V td6
15th Jan 2013 6:09pm |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 |
Or alternatively if you can grab it and stop it with your hand its fine, if you have no fingers left its not!!! One day your life will flash before your eyes......................................make sure yours is worth watching! |
15th Jan 2013 6:15pm |
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 |
Back to Joe90's post earlier where he asked is there some turning of the viscous fan. Just returned home and parked up for 10mins, temp gauge slap bang in the middle - no movement. Just started up to move back and temp gauge at 1/4, ok its -7 at the moment, FBH activates. Using the opportunity to check the fansd, i left it in idle, temp still at 1/4, FBH on, peering through the grill 'electric' fans still, but the viscous fan was turning - not with great gusto but all the same turning. Wondering if the turning is normal?. Bit long winded i know but...... |
17th Jan 2013 8:51pm |
jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147 |
The cable connects to this little wheel using a completely crappy bit of plastic. Mine broke, on the cold setting, of course. Remove the vent piece to see the plastic crap. That made me sad. Jim 2000 NAS HSE 2005 NAS HSE |
17th Jan 2013 10:47pm |
It will turn a bit with the engine, it locks more as the motor gets hotter. One day your life will flash before your eyes......................................make sure yours is worth watching! |
17th Jan 2013 10:52pm |
Thanks Johnny. I had a text exchange with the UK based [Hailsham] Chief Engineer last night. He said the same, some turning with engine in idle. Did the engine off test, fan turns both ways with a little resistance. So it's back to the drawing board. |
18th Jan 2013 7:43am |
Hi,
24th Nov 2013 12:27am |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
Could the thermostat be stuck open? 56 TDV8 Vogue SE
24th Nov 2013 9:15am |
Sounds like the thermostat to me too. Cheap place to start There is nothing that can't be fixed with a hammerðð
24th Nov 2013 9:25am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 |
Take the viscous fan off for a week and see what happens.
24th Nov 2013 10:40am |
HI, The main thermostat was changed, is there a second one.
24th Nov 2013 9:52pm |
Is there step by step guide on dismantling the viscose fan. -03V td6
24th Nov 2013 10:19pm |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
Do NOT run your rangy without the vicious fan.... You will blow your cylinder head gasket or crack your head
24th Nov 2013 10:53pm |
