Home > Technical (L322) > Transfer box motor? |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 |
That will take a while to try and source, I dont doubt RRPhil has tried but we work pretty closely with some electronics companies. One day your life will flash before your eyes......................................make sure yours is worth watching!
30th Jan 2013 11:11pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 915 |
The more people who can try to source a replacement potentiometer the better
31st Jan 2013 1:31am |
Glideman Member Since: 11 Sep 2011 Location: Stood next to a broken down Range Rover in Darwen Posts: 112 |
Do you still have a spare T/B motor Phil? Range Rover 4.4 V8 Vogue |
31st Jan 2013 3:23am |
What happened to gyrogypsie's solution, I did not realise someone had got so far with this. I wondered along the lines of reconditioning the potentiometer itself. One day your life will flash before your eyes......................................make sure yours is worth watching! |
31st Jan 2013 10:11am |
I have a spare armature & brush assembly but not a spare potentiometer I’m afraid. I gave my spare potentiometers to Gyrogypsy to help him spec. the replacement unit that he is working on. I haven’t heard back from him regarding progress with this for a while now. It’s worth running the motor on a bench to see if you can clean up the potentiometer wiper contacts to rejuvenate the thing. &list=PL063C3AB14BE6984C Phil |
31st Jan 2013 2:07pm |
I managed to find a local breakers with a second hand motor today for £250. I fitted it in about ten mins with just 3 10mm bolts and one electrical connector to remove.
31st Jan 2013 5:50pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6400 |
31st Jan 2013 6:38pm |
tymh Member Since: 21 Apr 2014 Location: Garstang Posts: 299 |
Sorry to resurrect a dead thread but...
24th Sep 2014 3:17pm |
roadnutter Member Since: 19 Sep 2013 Location: Bridge Of Weir Posts: 23 |
Hi Tim,
30th Sep 2014 11:20am |
I've taken it off twice now... once to test it, and the second time to wind the TB manually into high range.
1st Oct 2014 8:51pm |
docjones Member Since: 22 May 2013 Location: Helsinki Posts: 48 |
Hi,
13th Oct 2014 10:24am |
Good work docjones .
13th Oct 2014 3:09pm |
I'm tempted to take mine out, drill a small hole it in, fill it with WD40, spin it round for a while then drain it and seal the hole up again...
16th Oct 2014 9:59am |
I've been advised that a split drum in the gearbox can also lead to the trans failsafe mode situation... Tym (current) L322 3.6 TDV8 Vogue 2008 Tonga Green (previous) L322 4.4 LPG Vogue SE 2003 If it sticks, force it. If it breaks, it needs replacing anyway. |
1st Nov 2014 10:58pm |
