Home > Maintenance & Mods (L322) > Engine tuning
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Engine tuning
anyone tried this?
http://portal.jeengineering.co.uk/engines/diesel-tunes.html
am thinking of having it done to the FFRR !
Post #178721 20th Mar 2013 8:26pm
Think there have been a few …. Thumbs Up ====================================
Post #178727 20th Mar 2013 8:32pm
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
does it drop the amount of engine revs that you have to do to cruise on the motorway at 80 mph? so the car becomes quieter?
Post #178862 21st Mar 2013 1:36pm
Buz1500
United Kingdom 2019 Range Rover Autobiography SDV8 Carpathian Grey
Had mine (TDV8) modified last year by JE. The care felt totally different afterwards, a lot smoother and gearbox doesn't drop down a gear as often. Makes towing my large twin axles caravan a breeze.
Very Happy
Post #178868 21st Mar 2013 1:49pm
Andy it wont do that, thats the gearing. It will just make you get to 80 quicker Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #178871 21st Mar 2013 1:59pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Might not drop the revs, but might reduce the noise a little or increase MPG as it'll change the fuel/air mixtures and potentially use less fuel.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #178899 21st Mar 2013 3:11pm
Buz1500
The upgrade Improves the torque at lower revs so the gearbox doesn't need to change down as often when you press on the loud pedal. The gearbox ecu takes multiple feeds, not just speed and revs is my understanding.
Post #178960 21st Mar 2013 7:22pm
andyleeds
so it would sound l / feel like its not straining at the top end?
Post #179056 22nd Mar 2013 10:40am
save your money Andy, i wish i did...my remap was a waste of time but removing the egr valve and blanking it was a good move and cheaper as well...
your td6 should cruise at 80mph with not much strain on the engine.. ... - .- -.
Post #179057 22nd Mar 2013 10:49am
andyleeds
cheers stan, to be fair its easy at 80.... 90 is a different issue Wink
how easy was the egr thing? i see its on the wiki, whats the benefit? better running engine?
andy
Post #179060 22nd Mar 2013 11:05am
90-110 shouldnt be too bad. 110+ is the hard bit as its just out of puff then. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #179064 22nd Mar 2013 11:25am
@Andy, the egr blanking helps by having cool air going into the combustion area which helps with mpg and smoother running ...i did it quite easily.. ... - .- -.
Post #179066 22nd Mar 2013 11:47am
Rambles
Stan
so you had the JE remap for the FFRR? Complete waste of money? are their claims false about the increase in power and torque?
Post #179248 23rd Mar 2013 7:48am
mjdronfield
Mate.
Just get yourself over to Coventry and hang around for an hour.
One of the best mods you can do.
Don't think Stan went to JE.
EGR removal is quick and easy, well worth it, as not only is the air cooler going into the engine, but all the soot and black carbon sludge should stop building up in the intake pipes. Kit to do it is relatively cheap too.
I have a K&N air filter fitted, but may remove it, solely down to extra intake noise when accelerating.
Your TDV8 may be a different engine to mine, but the physics are still the same.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #179270 23rd Mar 2013 10:46am
robjp
Wales 2004 Range Rover Vogue Td6 Zambezi Silver
Regarding TD6 chipping ...
I recently bought Benjj's old TD6, which had to have a new engine and turbo 4 months after he had it chipped (chip was done at 102k, engine went bang at 106k
Might have been a coincidence .... but then again, he didn't have the replacement chipped. My plan was idiot-proof ...
Until someone designed a better idiot
Post #179341 23rd Mar 2013 3:17pm
