Home > Technical (L322) > Landrover Supplied Jack - Useless
elbitrevnoc
United Kingdom 2006 Range Rover Vogue SE Td6 Buckingham Blue
Just a word or warning for anyone that may be as foolhardy as me and assume that the jack supplied in the car is up to the job. I had a front wheel puncture last week (arrow shaped piece of flint went straight through the tread), which wasn't too much of a disaster as the two fronts were just about due to be changed.
I was parked up on a solid, level piece of ground, so I decided to stick the spare on. However, at the point at which the car was up on the jack and I pulled the wheel off the hub, the jack buckled and gave way. It all happened in a split-second, but by a stroke of luck, the wheel was still upright and in my hands. Consequently the wheel was caught as the car came down and cushioned what would otherwise have been a pretty terminal incident. That left me with the front o/s nose of the car near enough down on the floor and the wheel trapped underneath.
After a few phone calls and a bit of running around I came back with a couple of trolley jacks, which meant I could get the car back up, the trapped wheel out and the spare on. By a lucky miracle I got away with no more than a bit of scoring to the inside of the alloy, where the hub came down and no damage to the car (I've since had it checked out).
I know it's a big old thing, but you'd think you could trust the jack supplied for a quick up and down tyre change! As it is there was no harm done, but this could just as easily have been an expensive and, more seriously, dangerous incident. I dread to think what would have happened if my hands had been caught - I'd never play the violin again!
Post #180250 29th Mar 2013 1:36pm
you are indeed one of very many that have found that the supplied jack is useless....this has been mentioned here on the forum loads of times hence the many threads asking about trolley and bottle jacks..
saying that, i and a few others have used said supplied jack to do a wheel change without any problems... ... - .- -.
Post #180257 29th Mar 2013 1:53pm
elbitrevnoc
Thanks Stan. Yes, I've read those posts since the incident! You live and learn!
Post #180259 29th Mar 2013 2:02pm
the main thing is that you are ok and havnt been hurt in any way.. ... - .- -.
Post #180261 29th Mar 2013 2:09pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
I've used the jack to change a wheel before, wasn't a great experience although it didn't pose many problems. I think in future I'll try the air sus trick instead.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #180341 29th Mar 2013 8:17pm
I had no idea. Thanks for the warning.
Makes the spare a bit useless doesn't it?
Post #180368 29th Mar 2013 10:57pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Allseeingpie..
Do you have any more info on the "Air suspension trick"? I've searched but can;t find anything. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #180375 29th Mar 2013 11:35pm
simon1233
I have used the Landrover jack to change all 4 wheels twice a year since I have owned the vehicle and have had no issues with it so far...
Post #180379 30th Mar 2013 12:13am
