![]() | Home > Maintenance & Mods (L322) > Question after 2006 facelift conversion |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
I am not sure if it is 'safe' to wire the cornering lamps up to come on with fogs/ side lights or dipped beams like some have suggested. I am sure I read somewhere that there have been incidences of lamp units being damaged by heat from the cornering lamps if they have been on for a longer than 'normal' time 56 TDV8 Vogue SE
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 ![]() ![]() ![]() |
One washer plug has 3 wires the other has 4 its the plug with 4 wires you need
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Why not just plug back in your wiper motors? |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1762 ![]() ![]() ![]() |
Because the facelift does not have wipers - it's jets now with no room on the bumper for the wipers. Ash
And thanks Johnny - I'll give that a try..! |
Read the reply again my friend... Should think i of all people would know the wipers won't fit after facelift!!! ![]() ![]() |
Hi Craig - Wasn't suggesting you didn't know but still not sure of your answer re wiper motors (Unless you mean just the motors and attach them out of the way inside the engine bay..!!)
i will have to have a look at my one, its covered in heat shrink so i will cut it back and see, you could always jump the connection from the windscreen pump, just means it will squirt with the windscreen washers but will work the same.. V8 facelift Range Rover Autobiography 22" wheels.
Thanks Dave,
Doh - Of course it is Craig - Thx for that.
Can anyone confirm if I need to use this bracket for the bumper please on the retrofit conversion.
