Home > Maintenance & Mods (L322) > Question after 2006 facelift conversion
Page 2 of 3 <123>
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
I am not sure if it is 'safe' to wire the cornering lamps up to come on with fogs/ side lights or dipped beams like some have suggested. I am sure I read somewhere that there have been incidences of lamp units being damaged by heat from the cornering lamps if they have been on for a longer than 'normal' time 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #181910 8th Apr 2013 9:17pm
daveo
dont run the halogen lamps in the cornering lights they will burn the reflector, will be ok if you change them for led's, with the headlamp washers i will have to check the colours but they were the ones in an old pm to me, may be graig from cam tech might have the colours V8 facelift Range Rover Autobiography 22" wheels.
Post #181917 8th Apr 2013 9:38pm
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
One washer plug has 3 wires the other has 4 its the plug with 4 wires you need
You need to connect the black with yellow stripe to the black with brown stripe..
You should have a solid brown and a grey with red stripe leave these two alone. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #181940 9th Apr 2013 7:51am
Why not just plug back in your wiper motors? Rolling Eyes
Post #181942 9th Apr 2013 8:05am
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Because the facelift does not have wipers - it's jets now with no room on the bumper for the wipers. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #181944 9th Apr 2013 8:10am
comports
And thanks Johnny - I'll give that a try..! Thumbs Up Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #181945 9th Apr 2013 8:12am
Read the reply again my friend... Should think i of all people would know the wipers won't fit after facelift!!! Yawn Banging Head
Post #181946 9th Apr 2013 8:15am
comports
Hi Craig - Wasn't suggesting you didn't know but still not sure of your answer re wiper motors (Unless you mean just the motors and attach them out of the way inside the engine bay..!!)
Sorry if I'm being thick! Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #181963 9th Apr 2013 9:33am
comports
Big Cry
Still can't get it to work. Connected the correct wires and pulled the stalk numerous times and then tried the button numerous times but nothing.
Any clues?
Does anyone know what plug goes to what pump (colour wise)
I have the new high power pump wired to the plug bypassing the old pump and pipe work wise- old pump plumbed in feeding new pump then on to the headlight washer feed.
I guess I'll have to pull out the washer bottle again and start again! Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #182036 9th Apr 2013 6:55pm
daveo
i will have to have a look at my one, its covered in heat shrink so i will cut it back and see, you could always jump the connection from the windscreen pump, just means it will squirt with the windscreen washers but will work the same.. V8 facelift Range Rover Autobiography 22" wheels.
Post #182070 9th Apr 2013 9:14pm
comports
Thanks Dave,
Whilst you're in there, could you see if you can spot the colour wires going to the 3 pumps. I took all the wires off to get the bottle out to see if the new pump would fit but it doesn't. I may have put the plugs back on the wrong pumps push the stalk and the rear still squirts, pull the stalk and the windscreen pumps. The button on the stalk also pumps the windscreen and not sure it that is correct.
Cheers
The only reason I;m worrying is the MOT is due end o f the month so need to get it working by then.! Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #182074 9th Apr 2013 9:18pm
Ash, you only need to plug your motors back in behind the panels as the motors make the pump work...
Also to note you asked in a previous post why your windscreen washers work either by pulling the right lever or pressing the end button?... The button on the end is to wash your windscreen whilst your rear wiper is switched on Thumbs Up
Craig
Post #182122 10th Apr 2013 12:48am
comports
Doh - Of course it is Craig - Thx for that.
ps - Just plugged the old wiper motors in and no change so something is wrong somewhere..! Not sure where to turn now though. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #182277 10th Apr 2013 8:33pm
daveo
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  V8 facelift Range Rover Autobiography 22" wheels.
Post #182613 12th Apr 2013 9:18pm
comports
Can anyone confirm if I need to use this bracket for the bumper please on the retrofit conversion.
http://www.ebay.co.uk/itm/LAND-ROVER-FENDE...7675.l2557
Not sure how it attaches but will have a look - Just wonder if it was a left over from the previous owners 2010 upgrade and not needed for a 2004 car.
Thanks Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #182664 13th Apr 2013 8:21am
Page 2 of 3 <123>
