Home > Technical (L322) > Re Range Rover Vogue 55 REG Starting problem
glenyboy26
England 2005 Range Rover Vogue Td6 Zambezi Silver
Hi
I had a problem 2 weeks ago, when i turned the key it would turn over but not fire up but only sometimes and other times it would work, so i took to garage and they said that it was battery, new battery fitted done approx 400 miles since then and today it did it again, my wife drove 10 miles, stopped and 1 hour later tried to start it turned over but didnt fire up, so she tried again and it worked, she drove 2 miles filled up and tried to start again, it was 3 times of trying then on the 4th go it fired up, she got home and i checked it fired up everytime, so i ran it to the garage and they checked it all again it was fine, battery alternator all reading fine and no faults???
any ideas will be great help
thanks in advance
Glen
Post #182010 9th Apr 2013 3:44pm
ebajema
There are a number of threads on here that have had similar issues. Sometimes it can be the barrel, sometimes the starter switch. Have a look with search and you should find them. Good luck. MY 2010 5.0 SC Galway green and sand interior!!
Post #182011 9th Apr 2013 3:49pm
Diesel or petrol? There is nothing that can't be fixed with a hammer😜😜
Post #182077 9th Apr 2013 9:29pm
Dolphinboy
monkey, profile says 2005 TD6. (hover your cursor over his car image under his name and it should come up. Thumbs Up )
Post #182079 9th Apr 2013 9:32pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
If it turns over but does not start then it probably won't be the key or the barrel. If it was the key wouldn't turn or the engine would not turn over and try to fire I don't think.
You could check the low/high pressure pump - maybe not delivering enough fuel..? Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #182085 9th Apr 2013 9:44pm
Sorry on iphone cant do that....
However, i had a similar problem on the m57 engine in my 530d, turned out to be a faulty injector. Worth getting the codes read as a faulty injector will show a fault code. Will probably save a bit of runni g round guessing as well.
There are a few chaps on here who have swapped them out so it seems to be eminently doable and they can be bought reconditioned. There is nothing that can't be fixed with a hammer😜😜
Post #182090 9th Apr 2013 9:53pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
On iPhone / iPad you can tap the car icon under their username to see what they have.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #182129 10th Apr 2013 7:50am
glenyboy26
cheers for info so far
it is deisel BTW , my misses has taken it out today and so far started everytime so the garage are saying use it till it does it again and then hopefully will come up with fault, so it not great not knowing if and when we going to break down,
is it on a main delaer that can read the injector codes or normal garage?
thanks again
glen
Post #182174 10th Apr 2013 1:48pm
ebajema
There are a number of code readers that can read the faults as the port is OBD II standard, depending on what equipment the garage has. But you don't necessarily have to go to the main dealers. Other option, is looking for members of FFRR close by with diagnostic equipment that can and want to help Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #182178 10th Apr 2013 2:02pm
Samp
Range rover vogue won't start sometimes..
Hi there. I have a similar problem with my 2003 range rover vogue. It's a diesel. Sometimes it starts and sometimes it plays up. Last week I had had it lifted on a low bed for 140km and when we got home after paying $400 to the recovery guys, guess what, it started!!! And yesterday it would not start.!! Checked it again after 4 hours, it started! By the way it has a new starter motor. What could be the problem guys? Help..
Post #271862 20th Jul 2014 7:21am
adigorn
Fuel pressure related to me
Most likely remote fuel pump
but needs to be diagnosed Thumbs Up
Post #271866 20th Jul 2014 9:19am
Fuel pump, READ THE WIKI!!! do a search for it and have a read Thumbs Up
Post #271873 20th Jul 2014 9:37am
