![]() | Home > Technical (L322) > Kick Plates - How to remove |
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 ![]() ![]() ![]() |
Just lever them up with a large flat blade screwdriver. They're only clipped on. To replace line the clips back up and smack it back on. 5.0 supercharged autobiography
Cheers |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
I'd recommend getting some of the clips before you have a go, they aren't usually expensive (usually 20-70p a clip depending on where it sits). That way you can wrench it off and just swap the clips over. I've found that putting new clips in the door cards and some of the pillars helped decrease squeaks and rattles massively. |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
DO NOT use a screwdriver, this is not the tool for the job, get a PLASTIC trim removal tool or worst case senario, a kitchen flat blade thingy.
I am with verydisco on this. Use a spatula or palette knife from the kitchen |
