![]() | Home > Technical (L322) > Kick Plates - How to remove |
| Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191
Just lever them up with a large flat blade screwdriver. They're only clipped on. To replace line the clips back up and smack it back on. 5.0 supercharged autobiography
| pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218
Cheers |
| TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848
I'd recommend getting some of the clips before you have a go, they aren't usually expensive (usually 20-70p a clip depending on where it sits). That way you can wrench it off and just swap the clips over. I've found that putting new clips in the door cards and some of the pillars helped decrease squeaks and rattles massively. |
| verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952
DO NOT use a screwdriver, this is not the tool for the job, get a PLASTIC trim removal tool or worst case senario, a kitchen flat blade thingy.
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
I am with verydisco on this. Use a spatula or palette knife from the kitchen |
| All times are GMT |
