![]() | Home > Technical (L322) > Range rover chassis measurements |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Outer top edge to outer top edge of the rubber pips: 1297mm |
texpis Member Since: 29 Nov 2010 Location: Stockton-on-tees Posts: 53 ![]() ![]() ![]() |
Thanks joe, looks like its moved 7mm the rest of the chassis etc is unmoved. Will hire |
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 ![]() ![]() |
Hi Mick
Hi Paneldamage
Nice work Mick, it's good to see what can be done if you don't mind getting stuck in.... How much for the inner wing if you don't mind me asking? I need the front 4 inches of the O/S wing for mine, I am hoping there will be a repair section for this bit to save doing the whole wing.
Hi Panel damage
