|  | Home > Technical (L322) > Range rover chassis measurements |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434   | Outer top edge to outer top edge of the rubber pips: 1297mm    | ||
| texpis Member Since: 29 Nov 2010 Location: Stockton-on-tees Posts: 53     | Thanks joe, looks like its moved 7mm the rest of the chassis etc is unmoved. Will hire  | ||
| paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222   | Hi Mick
| texpis Member Since: 29 Nov 2010 Location: Stockton-on-tees Posts: 53     | Hi Paneldamage
| paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222   | Nice work Mick, it's good to see what can be done if you don't mind getting stuck in.... How much for the inner wing if you don't mind me asking?  I need the front 4 inches of the O/S wing for mine, I am hoping there will be a repair section for this bit to save doing the whole wing.
| texpis Member Since: 29 Nov 2010 Location: Stockton-on-tees Posts: 53     | Hi Panel damage
| Posting Rules
