Home > Technical (L322) > Range rover chassis measurements |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34925 |
the first thing that springs to mind is RAVE, anything on there ?. ... - .- -.
21st May 2013 4:14pm |
texpis Member Since: 29 Nov 2010 Location: Stockton-on-tees Posts: 53 |
looked in there cant see anything.
21st May 2013 4:42pm |
aah, ok..
21st May 2013 4:44pm |
If you take pictures and give instructions of the measurements you want, I'd be happy to do a bit of measuring..... .
21st May 2013 5:34pm |
Cheers for the offer joe will do some tomorrow
21st May 2013 6:35pm |
Hi Joe as you can see the damage is more at the top haven't stripped it yet but suspect the turret ant the top could have moved in a couple of CMs. could you measure between the turret bolts that hold the suspension air bags for me please.
21st May 2013 8:43pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 911 |
I think that the information you’re after is in the Service Procedures section of RAVE
21st May 2013 8:58pm |
Aha thanks for that Phil looked at rave but didn't look there
21st May 2013 9:15pm |
Well, just out of interest I went out to have a measure on "C"
21st May 2013 9:36pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
Mick, it doesn't look hard enough to have moved the strutt top! Normally the cost of parts is the big killer when you hit the front corner...
21st May 2013 9:39pm |
Hi joe yes it looks a bit sad hopefully will get it sorted garage recon 14k to repair
21st May 2013 10:08pm |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 |
At £14k to repair you're probably in "break it up and buy a facelift" territory unfortunately
22nd May 2013 7:44am |
RRPhils post needs to go in the WIKI.... |
22nd May 2013 8:30am |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Is there other damage we can't see in the photos? That really does not look like 14k worth of damage. Previously..
22nd May 2013 8:50am |
