|  | Home > Technical (L322) > Range rover chassis measurements |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434    | Outer top edge to outer top edge of the rubber pips: 1297mm    | ||
|  22nd May 2013 6:06pm |
| texpis Member Since: 29 Nov 2010 Location: Stockton-on-tees Posts: 53      | Thanks joe, looks like its moved 7mm the rest of the chassis etc is unmoved. Will hire  | ||
|  24th May 2013 6:24pm |
| paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222    | Hi Mick
|  25th Jun 2013 10:51pm |
| texpis Member Since: 29 Nov 2010 Location: Stockton-on-tees Posts: 53      | Hi Paneldamage
|  27th Jun 2013 6:39pm |
| paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222    | Nice work Mick, it's good to see what can be done if you don't mind getting stuck in.... How much for the inner wing if you don't mind me asking?  I need the front 4 inches of the O/S wing for mine, I am hoping there will be a repair section for this bit to save doing the whole wing.
|  27th Jun 2013 9:49pm |
| texpis Member Since: 29 Nov 2010 Location: Stockton-on-tees Posts: 53      | Hi Panel damage
|  29th Jun 2013 8:39am |
| Posting Rules
 some hydraulic gear to move it back.
