Home > Maintenance & Mods (L322) > Loosing the will to live,
Jordanschroeder
United Kingdom 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Dear god please help me !! I'm a going out of my mind little woman with a l322 that overheats when stuck in traffic!!!! I've had a new radiator, changed fluids etc even contemplated getting it blessed by a catholic priest !!! Can I possibly fit an external fan to stop this happen, I'm sick of spending money on it !! It's either that or setting fire to the fecking thing!!!
Thanks in advance Dizzybint
Post #192554 7th Jun 2013 3:21pm
wslr
United Kingdom 2010 Range Rover Vogue SE TDV8 Atacama Sand
Is the thermostat operating? Is the system clean?
Before you burn it, I will give you £100 for it. Whistle
Post #192555 7th Jun 2013 3:24pm
Advanced Factors
Site Sponsor
I am no expert in these, I spend my time usually in the Disco3 Forum where I am in my comfort zone, but I notice that the water pump fitted to your engine was a common BMW water pump and many of these suffered from the impellor coming loose and so not pumping properly, could this be your issue? Paul Redding
+44 (0)23 8052 2760
paul@advancedfactors.co.uk
Post #192558 7th Jun 2013 3:44pm
Hello and welcome... Bit harsh calling yourself a dizzy bint ! Laughing
The problem is..... The wrong person is looking at the car.. Take it somewhere else. The previous 2 posts were basic first test that should have been carried out. I take it the car is ok on longer runs, it's just crawling traffic that is the problem? Previously..
Post #192559 7th Jun 2013 3:57pm
Jordanschroeder
Sensors checked the mechanic said it was ok but I think he just likes the colour of my cheque book! Dizzybint
Post #192560 7th Jun 2013 4:03pm
A1GSS
No sensor on the water pump AFAIK. Got to be worth a look. Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #192562 7th Jun 2013 4:05pm
Jordanschroeder
Yup got it in one car is great on long runs just mega pants in traffic, I'm off to Bordeaux in it in August, well I say I am!!!, Dizzybint
Post #192564 7th Jun 2013 4:05pm
New Thermostat is only £65..... (Easy fit as well)
Post #192567 7th Jun 2013 4:09pm
ebajema
No idea how far you are from Cam Tech Craig and if you are too far away, I suggest to ask the forum for a reliable mechanic in your area. To me it sounds like your technician thinks Range Rover so they must be loaded (how wrong they are, the money pours out faster than with a bloody superyacht turning us into instant paupers with a nice car).
How quickly after the cold start does the engine warm up and how long before it overheats after that ? If that is fairly quick then the thermostat is closed.
Does setting the heater to full blast heating help cooling it down (even temporarily) that could indicate thermostat closed or bad circulation of the pump (impeller issues)
Running radiator cleaner through the system could be prudent to clean any crap out although the radiator is the most likely culprit for overheating and that has been replaced.
Is your cooling fan working properly ?? When the engine is quite hot (before overheating preferably) have a look under the bonnet and see if the fan is whirring away hard.
I had a similar problem with an old Mercedes in Las Vegas years ago. Turned out be the fan, the thermocoupling failed so the fan didn't work at all. They ended up (wasn't my car) making the fan fixed as a new coupling was 600 USD ! Like your L322, it only overheated in slow traffic and nowhere else.
Good luck Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #192568 7th Jun 2013 4:11pm
Advanced Factors
Site Sponsor
We supply Thermostat @ £46.38 Water Pump @ £39.20 both German products oddly enough Paul Redding
+44 (0)23 8052 2760
Post #192570 7th Jun 2013 4:14pm
wslr
If you connect the vehicle to Testbook and look at the live data, the engine ECU will only open the thermostat at around 105C. This is to keep the engine as hot as possible to keep the emissions as low as possible. If the thermostat doesn't open properly, then it cannot drop the engine temperature because it cannot use the radiator.
T4 shows 2 temperatures on the M62 engine. One the main engine coolant temp and also the temperature of the coolant after the radiator. You should see the engine opening the thermostat to regulate the temperatures so as one climbs the other should drop slightly.
It just needs someone who can connect T4/Testbook or similar to check this is happening. It is the only way really.
Post #192575 7th Jun 2013 4:57pm
what would the postage be on these Steve? ... - .- -.
Post #192576 7th Jun 2013 5:00pm
Or the old fashioned way... Take out the thermostat, drop it in a mug of boiling water and see if it moves.. Probably better doing it the high tech way though! Previously..
Post #192577 7th Jun 2013 5:02pm
If you have had fluid changed have they got all the air out properly? Use the hidden menu in he dash to get a numerical number on how hot she's getting. You can also mod the electric thermostat to be open perminantly that will reduce the overall temp by about 7-10deg. Obviously will mean it takes longer to heat up in winter etc. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #192578 7th Jun 2013 5:08pm
Advanced Factors
Site Sponsor
£6.50 courier Stan Paul Redding
+44 (0)23 8052 2760
Post #192592 7th Jun 2013 6:15pm
